Results 1 to 10 of 10
  1. Member bakonfreek's Avatar
    Aug 2012
    A Corn Field In Iowa
    My stepdad gave me a microSDXC card and the adapter that came with it to use in my camcorder. The camcorder is a Sony HDR-CX190. It is compatible with SDXC cards but when I go to use this in it (using the SDXC adapter) I get a C:13:01 error code. That's not the weirdest part though. When I put it in my computer (also SDXC compatible) it says to format the card and it wants to format it to not 64 GB but 36 MB. Any help in figuring this out would be apprecciated, I don't want to have to buy another card. The card is a SanDisk Ultra and the speed is UHS 1 (regular class 10 like my 32 GB card).
    Oct 2005
    666th portal
    maybe try a different adapter and see if the cam can recognize it. if it does have the cam format it. if not you could try the official sd card formatter from the sd association.
    https://www.sdcard.org/home/
    if that fails sandisk gives a lifetime warranty on that product.
  3. Member bakonfreek's Avatar
    Aug 2012
    I'll try the formatting tool. Hopefully it works.
  4. Member bakonfreek's Avatar
    Aug 2012
    Just like the computer, the formatting tool wants to format to 36 MB.
  5. It's very common for unscrupulous flash card sellers to take small cards and fake a larger size to sell if for more money. It looks like that's what you have. The problem goes unnoticed until the card starts to fill up and fail.
    This is about USB flash drives but the issue can be with any flash memory:
    http://en.wikipedia.org/wiki/USB_flash_drive#Fake_products
    There are web sites that tell you how to check the real size of your flash card.
  6. Member bakonfreek's Avatar
    Aug 2012
    I can understand that for some more unknown scam artists but I wouldn't expect SanDisk to do something like that...then again...
  7. Originally Posted by bakonfreek View Post
    Of course SanDisk wouldn't do that. But the manufacturer could be fake too. Depending on where it was bought. Or maybe it's just gone bad. At today's prices you might as well just throw it out if it's malfunctioning.
  8. Member bakonfreek's Avatar
    Aug 2012
    I'll see what the people at Best Buy can do for me (I'm expecting nothing really useful, it's best buy ).
  9. I think most of the fakes come via ebay.
  10. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    *** Now that you have read me, do some other things. ***
