    Aug 2009
    New Zealand
    http://www.youtube.com/watch?v=oLzaaLev-yc
    i have tried replay media catcher and it found nothing and i have tried a firefox video downloader addon it can download the video but shows a whole list of videos and each one is only 4sec
    i do not wish to screen rec it
  2. I think you may have to screen record. That is a live broadcast. There are no parts or sections to download.
    It's not saved as a selection of individual files on the server, but relayed as a series of packets.
    As you have probably seen already, the packets you can capture all have the same name; one seg effectively overwrites the next. It's like a TV signal, a one-way stream, but with larger packets and no way to rewind.
    Unless you use some sort of direct stream recorder or packet-sniffer which records direct to a video file, you're stuffed.
  3. REBROADCAST STARTS AT 2AM EST
    Maybe that will be a file.
    Aug 2009
    New Zealand
    i see the two i wanted to rec have been uploaded on there channel so i can just download off there
  5. 'Everything comes to he who waits...'
  6. Member vhelp's Avatar
    Mar 2001
    New York
    i screen capped the concert, but the quality was soo awful, heavily pixelated. it was only good to watch live (the music) then i deleted it anyway.
  7. Member vhelp's Avatar
    Mar 2001
    New York
    turns out i didn't delete the 605mb audio.wav file. for kicks, i encoded it to 26mb aac file. sounds pretty good enough to me. i think i'll keep it since it was a good concert, i liked the female deejay in that recording. anyway.
