want to use vhs to dvd 3 roxio on a fedora 17 need a step by step instruction on how to get fedora software to installing software
I just had a look out of curiosity. There is no linux version of roxio vhs to dvd. Just windows and mac.
Ideally you still have a windows partition on your machine. Otherwise you'll have to run it in a virtual machine using wine or something like virtualbox. Remember that if you run it virtualized you can't expect to get tech support from roxio.
You aren't likely to get step by step instruction here. Do a search on wine. There are lists of windows programs tested on it. Some programs work fine, others terribly or not at all. I have virtualbox installed but haven't used it yet.
I think your best bet if you have no windows partition would be to find a linux solution. I don't know of any linux capture tools but I'm sure they exist.
Have you tried fedora tech support or forums? I was under the impression fedora tech support wasn't free. I use ubuntu and mint, which is ubuntu based. It's different from fedora/redhat and I don't know that much about it. -
tried to install wine but problems their to, trying fedora forum and no news , no windows partition on drive so i guess am in a lots of trouble probably return the device and with device would you recommended, i still what it to work
Return the roxio whatever if possible. That software is not a liinux program. I hate to say this but if you couldn't even install wine configuring this sort of thing is going to be a problem.
Join the fedora forums and ask what programs and capture hardware they may have got to work.
Can Roxio USB capture be used without Roxio's software?
By miamicanes in forum Capturing and VCRReplies: 4Last Post: 18th Oct 2012, 17:30 -
Need Alternative To Roxio
By mlb32704 in forum Newbie / General discussionsReplies: 23Last Post: 9th Apr 2011, 19:50 -
Roxio ?
By reygato in forum EditingReplies: 3Last Post: 20th Apr 2010, 08:50 -
Roxio announces Toast 10
By terryj in forum MacReplies: 0Last Post: 6th Jan 2009, 09:44 -
Has Roxio Gone Too Far with Toast 9?
By terryj in forum MacReplies: 11Last Post: 28th Mar 2008, 15:54
