Hello
I bought the AVerTV HD capture to record TV broadcast signal via HDMI from my Voobox in the avermedia software I installed I just view the images but I can not save, Avermedia tells me that 'they are protected, I think the HDCP
I'm running Windows 7 64Bit Home in.
Can you help me get around this prohibition. thank you
The CaptureHD is the H727? Just use the same instructions as the C027.
https://forum.videohelp.com/threads/341920-Need-Original-Drivers-for-Avermedia-AverTV-H...=1#post2132428 -
Hello and thank you for your answer, there are two outputs on the box voo one HDMI and Scart ... unfortunately
Big thank you for your answers, I started capturing video dand ...
I can not download these two addresses given by Cauptain:
Link 1: http://www.mediafire.com/?6mfxeifodf4ad9b
Link 2: http://www.4shared.com/rar/YMNHr8KZ/...PROTECT_R.html
every time I have to download "illivid" I can not download the file, how should I do?
vaporeon800 you can explain: The CaptureHD is the H727? Just use the same instructions as the C027.
I forgot Cauptain with what you offer me I can record directly into the Avermedia software?Last edited by Helloyou; 16th Mar 2013 at 12:39.
Hello
A thousand thank you for your help, you make me a happy man ... it's been one month I was looking for a solution to my problem ... I could solve with you.
So how do I use VirtualDub to capture from the AverTV HD DVR?
By Asterra in forum Capturing and VCRReplies: 55Last Post: 15th Feb 2014, 23:42 -
DVI to Component to AverTV HD Express- YPbPr works on HDTV but not AverTV
By asperi in forum Capturing and VCRReplies: 1Last Post: 9th Jan 2012, 09:22 -
How to capture gameplay from XBOX360 to AVERTV capture card
By Ollie999 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2011, 20:16 -
Best Capture Card Under $150?? (AVerTV CaptureHD??)
By jenna12 in forum Capturing and VCRReplies: 7Last Post: 1st Apr 2010, 12:38 -
AVerMedia AVerTV Capture HD with GraphStudio problem
By feeltherock in forum Video Streaming DownloadingReplies: 0Last Post: 18th Feb 2010, 12:47
