  1. Hello ,I want help to rip my large m2ts/BDAV videos to a mkv file like this :
    General
    Unique ID : 246125104800661315933837514592090464363 (0xB929F88F87D928E5A7DEF6A13F16206B)
    Complete name : ??
    Format : Matroska
    Format version : Version 1
    File size : 4.27 GiB
    Duration : 53mn 3s
    Overall bit rate : 11.5 Mbps
    Movie name : ??
    Encoded date : ??
    Writing application : mkvmerge v2.4.2 ('Oh My God') built on Jan 18 2009 17:30:28
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 53mn 3s
    Bit rate : 11.1 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.224
    Stream size : 4.04 GiB (95%)
    Title : x.264 by ?? ~11128kbps
    Writing library : x264 core 60 r891kVAQ2mod.PsyRDO-generic-pf 2ca4593
    Encoding settings : cabac=1 / ref=3 / deblock=0:0:0 / analyse=0x3:0x133 / me=umh / subme=6 / rdcmp=psy / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=11128 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=3:3:0.60
    Language : English
    Default : Yes
    Forced : No
    Its an exellent rip with splendid quality and small size! Here is the "raw(remuxed)" file :
    General
    Complete name : ??
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 10.5 GiB
    Duration : 53mn 15s
    Overall bit rate : 28.1 Mbps
    Maximum Overall bit rate : 35.5 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format settings, ReFrames : 2 frames
    Codec ID : 27
    Duration : 53mn 0s
    Bit rate mode : Variable
    Color space : YUV
    Bit depth : 8 bits
    Please ,Give me a guide how I rip these m2ts/BDAV files to a quality rip as i mentioned first.
    Thank you!
    Mar 2011
    Nova Scotia, Canada
    There's a Guides section in the bar on the left hand of this site ...
  3. Originally Posted by Hoser Rob View Post
    Can you link the guide I need,please?
    Click on ripbot264 and guides.
    But you wont find any super guide to make very small size rips with decent quality. You must learn how to configure x264 then.
