This is the camera I have
http://www.amazon.com/Panasonic-HDC-SD1-Definition-Camcorder-Stabilized/dp/B000LO92EK/...-SD1+Panasonic
Love the picture, hate the audio, dont have more money to buy anything other than an external microphone.
What mic would hook into this cameras mixc jack? Does a shotgun microphone need an adapter to fit this smaller camcorder? Thanks for the help
if it has the normal small headphone jack sized mic-in you should check out the rode videomic or rode stereomic. b&h photo usually has them.
Ya its the typical smaller jack. Thanks man I appreciate it a lot Ill check those out
Here´s a thread with some suggestions for a simmilar problem as yours.
https://forum.videohelp.com/threads/349994-Panasonic-HDC-SDC750-Cam-(My-Review)
Good luck
Panasonic HDC-TM80 (HD) camcorder, just discovered painful format - HELP?
By nico1et in forum Newbie / General discussionsReplies: 0Last Post: 15th Dec 2012, 20:48 -
External Mic for Panasonic HDC-SDT750 Camcorder
By glenpinn in forum AudioReplies: 6Last Post: 14th Oct 2012, 05:28 -
External mic
By ipaddle4fun in forum Newbie / General discussionsReplies: 1Last Post: 7th Mar 2011, 22:46 -
Asus eeePC as an external monitor for Panasonic camcorder??
By Chilla1142 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 31st Dec 2010, 23:00 -
HDC-SD1
By Tyler2000 in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2008, 13:19
