Page 2 of 2
FirstFirst 1 2
Results 31 to 37 of 37
  1. One solution with hard subs:
    https://forum.videohelp.com/threads/312522-How-to-convert-an-h-264-MKV-with-softsubs-to...-with-hardsubs
    Better than nothing. Will it play on an Apple TV? No idea.
  2. I was thinking maybe YAMB. Found this and it got me thinking it might work. Me? I would be happy with the MKV
    https://forum.videohelp.com/threads/332670-Add-Soft-Subtitles-and-Chapters-to-m4v-mp4-%...-in-Windows%29
  3. If you try the MKVtoMP4 route you should probably reduce the level from 4.1 to 4.0 as Apple TV (AFIK) only support up to 4.0
  4. En Taro Lawllmaster lawllmaster's Avatar
    Mar 2013
    The U.S. of A
    Your suggestion is helpful, but I prefer to use the command tool (mp4box) rather than the GUI. And it does work, but only one downside: it only supports mp4 files. I re-encode multiple file types like avi and mkv.
  5. En Taro Lawllmaster lawllmaster's Avatar
    Mar 2013
    The U.S. of A
    I don't like hardsubs as it reduces video quality.
    Oh and storage is not a problem anymore, just went to Amazon and ordered 4 4TB hard drives to connect to my PC lol.
  6. Originally Posted by lawllmaster View Post
    Yes. I see. But if you have it in one container then you only (hopefully) have to demux and remux to a new container type. No quality loss...and it's very fast...no reconversion.
    Have fun with the new storage mountain
  7. En Taro Lawllmaster lawllmaster's Avatar
    Mar 2013
    The U.S. of A
    I'll look into it! Thanks for the suggestion!
    Oh and I will have fun with the 16 TB of storage. Now where can I put it in my PC... :P
