  1. Member vhelp's Avatar
    Mar 2001
    New York
    windows xp home sp2, NTFS system. the file was a plain text file aprox 400kb in size.
    hi all. another strange mistake i made while attempting to Load a file, by accident i click the Save button. i hate windows apps that have load/save soo close together. anyway. as soon as i realized what i did, i went straight to my prefered undelete utility, "GetDataBack for NTFS" but it is only showing me the file that i saved over but is reading 0 bytes, obviously. but i always thought that dos/windows "masks" file that are being saved over so that in the event you save a zero-size data (ie, saving a text file in notepad, file.txt=138kb now says file.txt=0) that it would still be recoverable. so i'm hoping there is something else i can use, or am i screwed ?
    does anyone have a suggestion to try before i decide to proceed and continue using this system to do some work?
    thank you in advanced.
    Nov 2003
    West Texas
    I've rarely had to try to recover deleted files, but the last time I used a free program called Recuva.
