hello i was filming a video with a mate on my mp4 player and then the battery died then i connected the mp4 player to the pc copied the video off opened with mpc and it dose not play only shows the first frame of the video and when i skip to parts of the video it dose nothing so i went and tried vlc player it did the same thing
so i have tried to convert it with Avidemux 2.6 the app crashes and handbreak just stays on scanning source
video is
Video
Format : MPEG-4 Visual
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Bit rate mode : Variable
Bit rate : 803 Kbps
Nominal bit rate : 2 000 Kbps
Maximum bit rate : 4 000 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate : 30.000 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.348
Stream size : 66.1 MiB (100%)
Language : English
Encoded date : UTC 2002-10-29 03:32:30
Tagged date : UTC 2002-10-29 03:32:30
mdhd_Duration : 4294966016
Audio
Format : AMR
Format/Info : Adaptive Multi-Rate
Format profile : Narrow band
Codec ID : samr
Bit rate mode : Constant
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Bit depth : 13 bits
if anybody knows how i can fix this it would be great because this is a really important video
the file wasn't closed correctly
the only thing i know, would be to use a HEX editor
open a good avi from the same source
and compare the opening header and the closing/end of file
of the the two avi files
the header usually contains the file info
such as file length (number of bytes)
and at what position the file actually starts (hex address of the start of the AVI file )
and other data -
Hi jamespoo
Looks like your 3gp file got corrupted. I would suggest to try to diagnose it for free using MP4repair.org. Then decide whether is worth to pay or not.
According to the post "How to repair damaged .3gp files" on their blog you could also try to change the container using ffmpeg to see if that would help.Best of luck!Code:ffmpeg -i input.3gp -vcodec copy -acodec copy output.mp4
--Fire -
Any way to fix a 3gp file
By fevs in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2013, 03:55 -
A corrupt file after sending a .3gp file via bluetooth
By ViDector in forum Video ConversionReplies: 3Last Post: 15th Aug 2011, 09:03 -
If anyone can fix this 3gp video file, I'll pay em £15 (via PayPal)
By prupert in forum Newbie / General discussionsReplies: 12Last Post: 1st Jul 2010, 05:25 -
3GP file size
By Jean777 in forum AudioReplies: 3Last Post: 24th Feb 2010, 16:36 -
corruptd .3gp file
By stikolyz in forum Video ConversionReplies: 0Last Post: 20th Jan 2010, 08:45
