  1. I have tried everything to play this file and can't do it. windows media player says it can't be played. I also installed VLC player but it will only play the audio. Any ideas of how to play this? I am running windows 7 ultimate
  2. what does mediainfo (view=>text) say about the file ?
    could it be damaged ?
    or some DRM protection ?
    where is it from ?
  3. Not sure what you mean by media info. When I put my mouse over it it just says type asf file 45.5 mb and 31 minutes long.
    Not sure if it is damaged. Like I said earlier I can get the audio to play in some software just can't see the video.
    Not sure if it is protected.
    The file is the recorded video stream from a webinar. I need to watch it for work training so I hope I can figure it out soon.
  4. mediainfo is a program that conveys information about the video/audio
    https://www.videohelp.com/tools/MediaInfo
    open the asf with mediainfo, use view=>text report back the information
  5. Here is what it says
  6. The fourcc is "G2M4", which is "GoToMeeting" Codec
    There is a download link to a decoder on this page
    http://wiki.multimedia.cx/index.php?title=GoToMeeting_Codec
    https://www4.gotomeeting.com/codec?Portal=www.gotomeeting.com
    Or some modified Mplayer binaries should be able to play it
    http://www.math.cas.cz/~kolar/software/g2m4_mplayer.html
  7. Worked like a charm! Thank you so much!!!!
