Guys (Baldrick?) is using VirtualDub still the best/easiest way to do this? There's a guide for it here from 2003 and I was wondering if there had been any development in the last ten years? I don't want to install the XViD codec so thanks.
The best way is not to join. The last video I joined was a vcd dat/mpg....
BUt if you must you could try avidemux, file->open and append, video and audio codec copy, select avi container, file->save as an new avi. No external video codecs are required.
Any advice against vdubmod "source rate adjustment" in AVI-XviDs?
By CactusMan in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2013, 17:33 -
Xvids from PAL sources on DVD Player
By rvman in forum Newbie / General discussionsReplies: 3Last Post: 18th May 2012, 14:04 -
Shrink Xvids to fit episodes on DVD
By Wolfbrain in forum Video ConversionReplies: 5Last Post: 20th Apr 2009, 11:40 -
adding packed bitstream to xvids
By pace508 in forum Newbie / General discussionsReplies: 6Last Post: 1st Jan 2009, 16:10 -
2 xvids codecs in vdub
By catdaddio6 in forum Video ConversionReplies: 1Last Post: 26th Aug 2008, 15:29
