I have a vcd that accompanies the textbook that I use in the Chinese primary school where I teach. It is really annoying to have to constantly queue it and have to hear the intro music, banner music, etc every time I want to change exercises. I want to cup out the video files that I need and put them into PowerPoint - actually, a program called OpenOffice Impress which is a clone of PPT. I an use the Impress command to import video and sound but the size of the video area is too small - only about 1/6 of the ppt slide. I need it to fill the slide. I have resized the displayed image of the DAT file so that it fills the screen but when I play the video, it reverts back to its original sizeAny suggestion? VLC will play the file at full screen size.
Try renaming the dat file to .mpg. If it plays then it's just mpeg-1. Search the forum for editing software.
I am wondering if it accompanies a textbook it might have some protection on it.
Let us know how it goes.
Edit: just found this. Never knew it was on here. Surprising what you find when you do a Search.
https://forum.videohelp.com/threads/88803-How-to-rip-the-video-from-%28S%29VCD-CDs-or-BIN-CUE-imagesLast edited by transporterfan; 11th Mar 2013 at 05:58.
Heheheh suprising what you find when you know which words to use to search on
I changed the extension to mpg and it works now. Thanks!
Converting file w/fixed dimensions to one where only vertical dim is known
By nehickel in forum Video ConversionReplies: 0Last Post: 22nd Oct 2009, 20:56 -
How to add black bars to Crop video without changing dimensions
By DavidCasillas in forum MacReplies: 6Last Post: 20th Sep 2009, 08:37 -
File Dimensions No Longer Show In Windows Explorer
By DarrellS in forum ComputerReplies: 15Last Post: 24th Feb 2009, 00:11 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 20:31 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 06:02
