Hi there!
I`m posting here because I have a few issues encoding anime DVDs when I can`t go with Forced Film on DGIndex.
Thing is, I never get good results when I try to IVTC anime. I have tried a number of AviSynth plugins and got the "best" results with TIVTC+TDient on MeGUI, but it leaves a lot be desired. Then again I'm not sure what kind of source I have (MeGUI's analysis always fails...).
I did get superb results with QTGMC, but it's a bob and can't IVTC. I ended up with a 60fps video.
I don't care if it will take a while to encode. Can anyone help me find a better way to do this?
Here's a sample VOB: https://docs.google.com/file/d/0ByvSeMrOEssgY2ZmZWhZQ1lHSkU/edit?usp=sharing
Thanks!
I haven't looked at your sample yet, but anime is often a mix of frame rates, progressive and interlaced. QTGCM() is the simplest method because they all meet at 60 fields per second.
Yes, your sample is a mix. So you can't IVTC to 24 fps. Is there a reason you can't live with 60p?Last edited by jagabo; 10th Mar 2013 at 11:50.
deinterlacing anime
By mmbwdpnz in forum Newbie / General discussionsReplies: 9Last Post: 3rd Nov 2012, 05:09 -
Restouring Anime
By LeoHenrique in forum RestorationReplies: 55Last Post: 21st Aug 2011, 12:48 -
Anime encoding help
By carasy in forum Video ConversionReplies: 3Last Post: 28th Nov 2010, 18:07 -
Encoding anime
By prnoct90 in forum Video ConversionReplies: 3Last Post: 25th Nov 2009, 05:38 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 15:31
