  1. a feww weeks ago i ripped the one
    useing the every vob option on smartripper
    and noticed it would split sceens in half so when the movie was joined
    you would get an annoying bleep
    then i ripped a second movie scary movie 2
    useing the max filesize option
    so i got just one file instead on 3
    then i put it into tmpg
    and started converting
    after about 13 min i noticed
    that the amont of frames being converted was way lower then it should have been
    i did the math and found out
    the piece being converted was only 55 min long
    i had every single chapter selected
    and the total size was less then the max limit
    can you tell me why this happened
    thx
  2. tell smartipper to split the movie by vobs
