when I set avi files with "ass" files to play subtitles, the videos (which usually run fine) lag. What can I do to make them run normal?
Moving you to our subtitle sectoin.
What are you playing with? Try something else like VLC Media player. -
Getting a new GPU or PC would be good.... Or as Baldrick suggests, try a different video player.
Convert the ASS to SRT. These are simpler -- no colours or fonts specced -- and should be easier to render, unless you are an anime fan and really want animated subs in 6 colours and fonts.
Maybe the subtitles and the video are at different frame rates and the original poster lacks the experience to know/understand this. This would be the simplest and most likely explanation. If I am right, the only realistic solution is to find a subtitle file at the same frame rate as the video, if you can.
In theory the subtitles could be converted to a different frame rate, but my experience is that this is extraordinarily complicated and I've almost never been able to get it to work correctly. -
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10
