dose anyone out there, know how to get mpeg2-svcd's to play on the sony dvp-s300?![]()
Check http://www.vcdhelp.com/dvdplayers.php?DVDnameid=419&Search=Search&#comments (top post have some info on the below described technique)
Assuming you can do as described with Sony DVP-NS300:
http://www.vcdhelp.com/dvdplayers.php?DVDnameid=630&Search=Search&#comments
Works like a charm on DVP-NS300! (But beware, your friends might not be able to borrow your 'mutated' 'S'VCD:s...)The Software you probably need:
(i)TMPGenc
(ii)Nero(if necessary)
-extract the mpg file from the bin and cue (isobuster works great for this)
-Using TMPGenc, do the following:
1 goto file/MPEG tools
2 select 'simple multiplex'
3 select type 'MPEG-1 Video-CD'
4 video input 'YOUR MPEG FILE'
5 output 'DESTINATION FOR YOUR FINISHED FILE'
6 run note: make sure that when you insert your file into the 'video input' that the select type option doesn't spring to 'MPEG2 program'. If it does then click 'MPEG-1 Video-CD'
again.
Next step:
Start NERO
using template Video-cd (you need to turn off the standard compliant option,
but as all your files have now a VCD header they should be able to fool NERO into
thinking they are really VCD files), add files and then burn.
This method has been tested by some people and it works great SO what are you waiting for??!!!
Enjoy!!
See also:http://www.geocities.com/newestmoviesencode/dvdvcd
HTH"The future is no longer what it used to be"
blu ray player firmware update removes media compatibility sony bdp-s300
By cdcutlip in forum DVD RippingReplies: 9Last Post: 8th May 2011, 03:03 -
issues playing burned DVD's on sony blu ray player bdp-s300
By cdcutlip in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th May 2011, 16:12 -
My Sony DVD player SONY DVP- NS718 H
By samyer in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2010, 00:56 -
sony dvp-ns708h
By mrmag in forum DVD & Blu-ray PlayersReplies: 4Last Post: 26th Jan 2009, 21:13 -
I have a Sony BDP S300 BluRay player, and the menu
By tzm in forum Authoring (Blu-ray)Replies: 2Last Post: 27th Mar 2008, 03:20
