  1. I have a problem playing some flv files
    files that won't open in MPC-HC. All other media players open them, e.g. Windows Media Player, VLC and Media Player Classic
    StormCodec7
    I received the following error message:
    SHN to Wave Filter::XForm Out
    Media Type 0:
    Audio: 0x0000 0Hz 0ch
    AM_MEDIA_TYPE:
    majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71}
    subtype: MEDIASUBTYPE_PCM {00000001-0000-0010-8000-00AA00389B71}
    formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A}
    bFixedSizeSamples: 1
    bTemporalCompression: 0
    lSampleSize: 1
    cbFormat: 18
    WAVEFORMATEX:
    wFormatTag: 0x0000
    nChannels: 0
    nSamplesPerSec: 0
    nAvgBytesPerSec: 0
    nBlockAlign: 0
    wBitsPerSample: 0
    cbSize: 0 (extra bytes)
    pbFormat:
    0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0010: 00 00 ..
    Please help in video and audio playback
  2. Is there a program to play the video
    Didn't it work with vlc,wmp,mpc?
    But try disable the built-in flv decoder in mpc-hc and see if it works better. I can't remember the exact settings right now.
  4. Easier to convert it to AVI and play it that way. Pazera has an audio extractor tool too.
    http://www.pazera-software.com/products/flv-to-avi-converter/
    You could try demuxing with FLV Extract , converting the audio to wav and remux to another format.
    A TS file maybe with TsMuxer. Hard to tell without a sample.
  5. Try opening the FLV files with MKVMergeGUI to remux them as MKVs (no re-encoding) and see what happens. Or under Source Filters/Internal Filters, try disabling FLV and restarting MPC-HC.
