Hello me again !
am i missing something here ... I have just learned how to use keyframing within Sony Vegas Platinum Movie Studio 11, but whenever i press animate within anything the programme will only allow me to keyframe 1-3 seconds .. am i missing something or is more seconds in the Pro version ? :-S
Thank you muchly peeps
xx <3
Thanks vkMast i will have a looksie now
@budwzr - cheeky ! just high on life my friend, high on life ! -
Hahaha.
The keyframing timeline, like the main timeline, can be zoomed in or out, depending on how detailed your animation. And what "domain" it's activated on.
Fer instance, Media, Track, or Event FX.
So if you apply an Event FX on a ten second clip, the keyframe timeline will only go ten seconds.
Kapeesh?
As a side note, from the looks of your work, you're ready for Vegas Pro. -
well i have just figured it, but yeah no it was defo 3 seconds on anything i wanted to animated even on a 4 minute clip - anyway i found a liccle button that said media properties and i can change the stream length and input the end time
(it must be a platinum 11 thing, because all the tutorials on keyframing movie studio that i have watched in the 10 version - all animation window is extended much further than 3 seconds :-p lol
yes i kapeesh now ! >dur me
thanks man x -
Ghost,
select a time range (e.g. click and drag along the Marker bar), right-click the track you want, insert your Text or Generated media, and you have the duration you want.
Difference in price between Sony Vegas Pro 11 & Sony Movie Studio Platinum
By Ghost Dust in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2013, 13:42 -
Does Sony Vegas Movie Studio HD Platinum 10 do 60fps?
By vid83 in forum EditingReplies: 13Last Post: 7th Feb 2011, 19:33 -
preview mode in the timeline Using Sony Vegas Studio Platinum 10
By JackDalton in forum EditingReplies: 5Last Post: 26th Oct 2010, 04:16 -
Sony Vegas Platinum 9.0 & Architech Studio 4.5
By bpinto0805 in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2009, 20:02 -
Sony Vegas Studio 8 Platinum Wipes
By luigi2000 in forum EditingReplies: 2Last Post: 30th Aug 2008, 15:46
