When I open AutoGK, I get the following message:
"Failed to set data for "VIDC.YV12""
I have
Windows 7 Home Premium Service PAK 1..
I have both Divx and Xvid installed.
I also have KLite 965 full Pak codec installed.
AutoGK worked at one time, but suddenly started giving me this message.
I tried using a restore point,with no success. I am still getting the message.
Can anyone tell me what I can do to fix the problem?
I would appreciate any help anyone can give me.
Thank you
Right click on the autogk shortcut and run as administrator. And try also disable your windows defender/antivirus application. See http://forum.doom9.org/showthread.php?p=893639#post893639 (simple google search on the error message)
Or just use something else to do dvd to xvid/divx conversions like video to video converter, freemake video converter.
DVD Decrypter error:Failed to set data for "DVDDecrypterPlayMovieOnArr
By rachelsmiley in forum DVD RippingReplies: 17Last Post: 22nd Dec 2017, 12:40 -
AutoMKV hangs with message "first normalizing volume - WAIT" message :(
By Jackie78 in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 06:33 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 14:46 -
Set/Fix QuickTime "atoms"/"flags"?
By rumplestiltskin in forum Newbie / General discussionsReplies: 3Last Post: 22nd Sep 2008, 14:07
When I open
