  1. I cannot capture any taller than 240 lines with my WINtv card. How do alot of you capture at ___ X 288 and higher? Thanks!!
    May 2001
    Denmark
    cassey,
    What software are you trying to use first of all ?
    ...and can you capture without any problems, using WinTVs own software ?!?
    Regards,
    John Brondum
  3. I use Vdub and can use the Wintv software but get the same result with both. I can use any width but get an error if I go over 240 tall.
    May 2001
    Denmark
    cassey,
    My next question would be what OS are you using and do you have the latest WinTV drivers for that OS ?!?
    Hauppauge have had many funny problems (and still have some), when it comes to their drivers and various problems with them.
    Regards,
    John Brondum
