i am about to reconfigure my hard drive for dual boot using partition magic my question ishow should i be installing software iread where i should keep my captures seperate from my system drive so should i be installing programs on my sytem drive or the drive i am saving everthing to ex. win 2000 system drive c
win 2000 my documents drive d
where should i put all of my applications
the same will apply to win 98se
thanx for all the info in advance![]()
The april edition of PC World Magazine talked about that. head over to www.pcworld.com to see if they put the artivle on the web.
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 02:06 -
dual-boot systems
By joecass in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2011, 21:01 -
system on C: but boot on D: (fix needed)
By deejay.2001 in forum ComputerReplies: 6Last Post: 11th Apr 2010, 14:04 -
[Solved] Backup software recommendations for a dual boot system
By freebird73717 in forum ComputerReplies: 3Last Post: 17th Nov 2009, 15:19 -
Creating a dual boot system...best way?
By sdsumike619 in forum ComputerReplies: 11Last Post: 14th Dec 2008, 12:30
