    Sep 2007
    somewhere in videohelp
    hi, i need some help here with PgcEdit, rum in win 7, already set compability ti win xp sp 2, in security already set to full control
    but still get this message :
    PgcEdit version 9.3 (March 22, 2010)
    Running as a wrapped script under FreeWrap v 6.42.4.
    Current character encoding: cp1252
    Console character encoding: cp437
    Error sourcing /Tcl/work/PGCEDIT/PgcEdit.tcl: invalid command name "::msgbox::MsgBox"
    () 1 %
    When you start it?
    It runs fine here. Win7 64bit. No compatibility mode settings.
    Sep 2007
    before it no problem, then it start error couple days ago, i didn't install any new application
  4. You do not need to set compatibility for XP. PgcEdit runs fine under Windows 7 and 8, 23 and 64-bit.
    If you have installed PgcEdit recently, try to clear your internet cache and re-download it from the home page.
    Also, your config files may be corrupt. Close PgcEdit, than go to "C:\users\[you]\appdata\roaming\PgcEdit" and delete (or move elsewhere) all config files in that folder. Relaunch PgcEdit.
    (The appdata folder is hidden. To open it easily, type "%appdata%\PgcEdit" in the search box of the Windows start menu.)
    r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
    - BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV
