When I convert a video clip MOV to AVI (about 20 secs worth or bigger) with Qicktime 5.0... Quicktime hangs at the end and won't complete the conversion. It does alright with smaller clips but the larger ones it seems to have a problem with. what could be the problem? Or what other program can I use to to convert from MOV to AVI ? ?
I assume you are exporting the whole AVI as a system. I would suggest exporting the audio and video seperately if you plan to convert to MPG. If not then I would suggest looking at getting Quicktime PRO if you do a lot of MOV to AVI.
Quicktime MOV to WMV3 in AVI Container
By kangmuchi82 in forum Video ConversionReplies: 5Last Post: 27th Sep 2011, 23:05 -
joining MOV files with quicktime
By natty in forum Newbie / General discussionsReplies: 5Last Post: 30th May 2009, 09:18 -
mov or mp4 file hangs my machine for a min.
By greendesert in forum Software PlayingReplies: 1Last Post: 4th May 2008, 13:50 -
trouble converting Quicktime mov. to avi (on windows XP)
By pifkel in forum Video ConversionReplies: 3Last Post: 31st Dec 2007, 04:19 -
quicktime (.mov) conversion
By superstarx85 in forum Video ConversionReplies: 0Last Post: 11th May 2007, 04:10
