Okay, If you downloaded something in MPEG format, could you just skip all the steps on making VCD to just burn it and watch it, when its on MPEG?
most often you can just burn the MPEG straight to VCD without converting anything (my experience anyhow) you can use Nero to burn VCDs. If for some reason Nero says it is not a compliant VCD format, then you can re-encode the file using the 'MPEG Tools' option in TMPGe, which can take anywhere from 5-10. After re-encoding, you should be ready to burn the disc!
Which format produces better quality overall MPEG-2, MPEG-4 or .x264?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2009, 03:00 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
rmvb format to mpeg conversion
By sumeshkri in forum Video ConversionReplies: 7Last Post: 2nd Oct 2008, 03:55 -
MPEG 1 -bit stream format
By banbuzz in forum ProgrammingReplies: 2Last Post: 25th Aug 2007, 12:36 -
Editing footage in MPEG-2 format
By RuckusVideo in forum EditingReplies: 6Last Post: 31st Jul 2007, 09:36
