Hi,
im subtitling a mkv file and since i dont want to lose any quality im trying to use the same conversion settings as the original. However, according to mediainfo, my writing library is libebml v0.7.7 + libmatroska v0.8.1 whereas the original was written with libebml v1.2.3 + libmatroska v1.3.0. Does it mean mine is outdated? I searched the net and i found this:
http://lists.matroska.org/pipermail/matroska-users/2011-September/004480.html
i downloaded the page but now im dont know what to do next. Could you please help me?
Thank you.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 16 of 16
This is my problem. I made my editing in virtualdub on a raw mkv and then i start frameserving. After that, i open the avs file with FormatFactory and choose the all to mkv option. I copy all the settings from the original and press convert. After the video is finished. I open it with mediainfo and some of the data is still different to the original, such as the writing library and that. Also, despite i use the same nominal bitrate as the original, i get a lossy quality video. What can i do?
Thank you. -
You will lose quality if you are reconverting/hardcoding subtitles. EVEN if you use same bitrate or higher bitrate. But try increase the bitrate or use x264 constant quality/quantizer encoding and make some short test samples.
The mkv writing libraray doesn't matter. -
I haven't used format factory for a long time.
What can you select under the encoding settings? Just bitrate? No 2-pass, vbr, cq-settings? -
These are the settings:
it hasnt to be with format factory, if you know a better program im open to suggestions. -
Anyway, these are the settings of the original file, which im trying to preserve but i just cant.
Code:Format : Matroska Format version : Version 2 File size : 513 MiB Duration : 27mn 22s Overall bit rate : 2 620 Kbps Encoded date : UTC 2013-02-27 21:06:42 Writing application : mkvmerge v5.2.0 ('I can't explain') built on Dec 18 2011 18:12:03 Writing library : libebml v1.2.3 + libmatroska v1.3.0 Attachment : Yes Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 27mn 22s Nominal bit rate : 3 072 Kbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 30.303 fps Original frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.049 Writing library : x264 core 120 r2120 0c7dab9 Encoding settings : cabac=1 / ref=4 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=8 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=3072 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=6144 / vbv_bufsize=15360 / nal_hrd=none / ip_ratio=1.40 / aq=1:0.60 Default : Yes Forced : Yes Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : A_AAC Duration : 27mn 22s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy Default : Yes Forced : Yes
Hi, i had tried megui before but i dumped it because i cant encode from frames served by virtualdub with it. I downloaded it again now and still the same problem. It says it cant locate the stream, which is bullshit because all the other programs can. Is there any way to fix this?
I don't know what supports virtualdub frameserver...I have only used it with tmpgenc about 10 years ago. .
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
AVIAddXSubs matroska support?
By therock003 in forum SubtitleReplies: 9Last Post: 3rd Mar 2010, 08:21 -
Demux Matroska files
By Anicsi in forum MacReplies: 4Last Post: 16th Dec 2009, 12:41 -
Using Matroska splitter or related
By Blå_Mocka in forum Newbie / General discussionsReplies: 8Last Post: 1st Nov 2009, 12:05
