I have some VCD's that I used a Terapin to record. How would I be able to remove the television logs that are annoying to see in the corner of the screen. :roll:
Mr.ButterWorth
If you'r using VirtualDub I believe there is an add-on plug in filter you can get that does this. I've never tried it but you might want to try it out. If you go to the VirtualDub home page there is a link that will take you to a filters web site. Hope this helps.
Mark
Remove Spoilers, Logos etc.
By illogical in forum User guidesReplies: 18Last Post: 17th Feb 2017, 09:25 -
remove a logo using two videos
By mathmax in forum Newbie / General discussionsReplies: 32Last Post: 20th Sep 2011, 21:31 -
Remove Logos
By Bob740 in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2010, 13:19 -
easy way to remove alpha logos (with no opaque parts)
By dumbledore in forum EditingReplies: 1Last Post: 16th Feb 2010, 19:22 -
How to remove TV logos on a specified range? (15:22:10 to 15:23:20)
By BlooderButcher in forum EditingReplies: 3Last Post: 28th Jul 2007, 00:01
