Results 1 to 9 of 9
  1. <>
  2. Bob the video then and count the number of unique pictures per second during movement.
    http://www.afterdawn.com/guides/archive/digital_video_fundamentals-ivtc.cfm
  3. <>
  4. Just count the number of duplicate frames per second and remove them.
    You said all your sources are 59.94fps. The most likely number of dupes in a second (usually containing 60 frames) are:
    zero: keep it at 59.94fps
    thirty: remove every other frame (SelectEven/Odd) to make it 29.97fps.
    thirty-six: SelectEven.TDecimate to make it 23.976fps.
    Originally Posted by bobp127001 View Post
    I am now capturing a TV movie and I have no idea if it will be film or video.
    If it's a movie, by definition it wasn't shot on video but on film, and it'll be 23.976fps.
  5. <>
  6. So you have a 59.94 fps video that was originally 23.976 fps film.
  7. <>
  8. Originally Posted by bobp127001 View Post
    In the past, I have done TDecimate(mode=0,cycle=5,cycleR=3). I'm not sure what the difference between those two commands is (perhaps the second TDecimate somehow integrates SelectEven()), so I'm hoping manono's command works as well.
    In your case you have:
     00111223334455566777
    Each digit represents a frame, the value of the digit is the frame number. Ie, 8 frames are repeated with a 2:3 repeat pattern to become 20.
    TDecimate(mode=0,cycle=5,cycleR=3) frist breaks it down into 5 frame groups:
     00111 22333 44555 66777
    then removes 3 duplicates from each group
    leaving
    SelectEven().TDecimate() first removes every other frame:
     0 1 1 2 3 4 5 5 6 7
    breaks the sequence into groups of 5
    then removes one duplicate in each group
    leaving
    They may occasionally give slightly different results at cadence breaks, the boundary between a moving sequence and a still sequence, etc.
    By the way, with progressive frames you just need to count the duplicates, no need to bob first.
  9. <>
