I have an mkv file, which has one video and 1 audio track. The audio out of sync. Using a +1000ms audio delay in vlc makes it sync.
So i'm trying to re-encode with https://www.videohelp.com/tools/MKVtoolnix to get audio sync
I believeswitch should be used to do this. But it requires track ID to do the job(as said in the mkvmerge document).HTML Code:-y
Now, how do i find out the track ID? When i tried
mkvmerge -i e.mka
it throws me an error:
Error: The source file 'e.mka' could not be opened successfully, or retrieving i
ts size by seeking to the end did not work.
Opening the file in mkvmergeGUI doesn't show the TID either.
Also, is it necessary for the input file to be present in the mkvmerge directory (the one which is defined in the environment variables)? Because, if i place the input file in any other directory, then i am supposed to five the directory location along with the filename, but the -i switch states that it won't take anything other than the filename itself.
P.S: It seems that there are confusions with "track ID". I believe that the required TID in this case is the one something like 12345 and not 01 or 02.
I also saw some dated discussions on TID here, but couldn't get what they were talking:
https://trac.bunkus.org/ticket/695
http://forum.doom9.org/archive/index.php/t-155732.html (while in this page, search for "identify" to see the TID related conversations)
You can just load it into mkvmergegui, set your delay and remux new mkv, or do you just want to find some command line solution?
as for command line solution, you get track ID first with one line and then use -y in another command line, example here: http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvmerge.html#mkvmerge.examples
Sony Vegas Automated track volume based off separate track?
By Mitalis in forum EditingReplies: 5Last Post: 18th Nov 2012, 17:51 -
need to equalize volume of a single track made by appending 3 track
By perfection in forum AudioReplies: 2Last Post: 23rd May 2011, 02:57 -
MKVMerge problem , audio out of sync - says This AC3 track contains 227 byt
By PSPGamer in forum DVD RippingReplies: 2Last Post: 20th Apr 2011, 16:38 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16
