Hello, all VH.com people!
As specified in the topic, I have encountered an odd DVD copying problem, which feels hard to describe in less than a hundred letters.
I have a DVD-format movie, copied on my HDD from the DVD-disc, in VIDEO_TS and .VOB format. I have tried to use several different DVD shrinking, decrypting etc. software, trial, shareware and free software (including several versions of DVDfab, DVD Shrink etc.) to decrypt the movie and cut it down to a size that fits a DVD5 DVD+R disc. Eg. from 7GB to 4,6GB. Which would easily be accomplished by cutting away the extras and multiple audio tracks.
What intrigues me, is that for some reason or another, VLC Media Player seems to be able to play the DVD folder, that includes the VIDEO_TS and AUDIO_TS folders, without a problem — even though it's just a Windows 7 Explorer copy-and-paste job — while no other software seems to be able to do that. Not MPC-HC/Media Player Classic, at least not without ffdshow, nor the aforementioned ripper/decrypter/shrinker software.
When run, the aforementioned software seems to process and finish successfully, but can't seem to show a preview of the video, nor produce a watchable result file. Regardless of whether I enable or disable the CSS removal systems, PathPlayers and so on.
The thing I'm wondering is, how does VLC handle the folders/files so differently from the other software mentioned? Why can it play the files while these other powerful apps can't seem to do squat? And could it somehow be helped?
I spent about whole last night trying to google solutions or tips as to how this could be fixed, but no-one seemed to be reporting quite similar issues.
Oh yes, the film is a Nordic release of a 2010 film published by DreamWorks/Paramount. And I'm indeed running Win7.
Thank you for any replies.![]()
If you used copy-paste to copy from DVD to hard drive you now have a CSS encrypted VIDEO_TS folder on your HDD. So, it's only natural that most software you use to open that folder does not work. On the contrary, VLC media player incorporates libdvdcss, a library that enables CSS decryption directly on the VOB files.
The CSS removal option on programs like DVDFab and so on, only work on the original DVD disk and not on VIDEO_TS folders on your hard disk. This happens this way because such programs need the encryption key stored on the DVD."The greatest trick the Devil ever pulled was convincing the world he didn't exist." -
Thank you very much, Keyser, for your quick and evidently accurate answer.
Good to know!
- S.
What software is best to use for multiple titles with multiple scenes?
By usalabs in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2012, 23:10 -
Can you copy multiple mini-DVD discs to one standard DVD?
By darkcyber in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 2nd Jan 2011, 09:44 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Need help with odd problem with erasing/recording DVD+RW
By fdm2000 in forum ComputerReplies: 17Last Post: 3rd Nov 2008, 18:02 -
Help with odd problem recording/erasing DVD+RWs
By fdm2000 in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2008, 08:24
