I decided to try MMC 7.5 and see if it improved upon the buggy MMC 7.5 however things like ati scheduler no longer always kicked in or the screen flickered and then it kicked in 15 seconds later, and sometimes during captures it wouldn't save the capture file.
That being said, I uninstalled 7.5 then uninstall the 7.1 install I had used to upgrade to 7.5, then I rebooted and installed 7.1 again, everything works however atisched.exe crashes on mfc42.dll <running xp> whenever the scheduler is supposed to kick in, is there some file that hasn't been removed or some registry setting left behind or someone who found out a workaround for this problem?
Please let me know and thanks in advance
Acru
go to the how to capture on the left. then look at the guide how to capture with the all in wonder. it will tell you how to uninstall MMC, then how to properly reinstall MMC.
May the force be with you. -
Did that already, 7.5 is leaving something behind not covered in the help/readme files.
Acru :cry:
How do i get an iso to burn properly?
By EdJr in forum Newbie / General discussionsReplies: 36Last Post: 23rd Jan 2012, 17:37 -
PC Doesn't Restart Properly
By bevills1 in forum ComputerReplies: 5Last Post: 5th Sep 2010, 22:20 -
How to remove the remove redundant tracks of *.ts?
By UMO in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 01:30 -
DVDs not playing properly
By peter31 in forum Newbie / General discussionsReplies: 4Last Post: 27th Oct 2009, 09:24 -
Video Not Working Properly
By RamEEz in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2008, 20:23
