Oops, I just found it after initializing the player and workaround.
Just extract "logo.swf" file to logos folder and manually select it.
I didn't know that the logo is a part of the skin as I use an external logo.
By the way, did you report it to the dev?
ps. It can be a skin issue as the external logo.swf works correctly.
It must be a skin issue as the same logo works correctly in "EN [+] v3.1.dsf" skin without using it as an external logo.
Results 151 to 180 of 667
Iam currently on Daum PotPlayer 1.5.44221 beta and it still have some issues showing some dvd subtitles during playback!!!!
I have read toroughly the changelogs from daum potplayer and i have read that it has been "fixed" since 1.5.39145 beta
→ http://www.dvbsupport.net/info/potplayer.html ←
Yet, here i am trying to find an sollution to that exact same problem they supposed to have fixed !!
iam pulling my last mohican hairs out
here to find an sollution/workarround for this !!
Heh, you think that's bad. Just for kicks I finally updated from 'old faithful' 1.5.35491 to 1.5.40688 and just now 1.5.44221. Despite all the talk in the log of DXVA and VC-1 fixes, for me VC-1 with DXVA now runs like a jerky slideshow. This is made more obvious due to my older CPU (may not effect you guys with the latest h/w), but it used to run fairly smooth. That's why I've always preferred PP. I'm not sure at what stage it was broken, but it's a PITA.
Unfortunately it is a shame. Many programs and utilities now seem to be going to the 'latest and greatest' filters and codecs but that leaves a lot of videos that will not play well due to a number of reasons. I'm with you katipo, I always keep at least one level back that I KNOW works and if I don't get a chance to test well, I keep that version a long time.
Maybe I'm being too hard, it could be the fault of newer versions of ffcodec.dll (FFmpeg team) ?
Out of interest, I wonder how many people use the newer features like 'Game capture', 'FTP playback' or 'Chat' ?
BTW, I've coded a little addon to allow saving custom Video Profiles. It is sort of a complement to the existing control panel you get with most skins (but doesn't require this). My app shows the actual values and full range (more accurate than the on screen perc%). PowerDVD used to have this (still may). e.g. You can select: Original, Vivid, Bright, Theater, Custom (actually all are custom). It's still in development, but I may share if there's interest. I couldn't see any Plugins feature, SDK, or even a Help file with PotPlayer so did this the hard way. It only works with the Software video render as PP doesn't control the hardware video properties.
It may be something different you're experiencing than me. I've found the logo isn't centered only after stop while the playlist is docked, otherwise the logo stays centered (after resize it corrects itself). PP has numerous small things that are off, best you can do is report them to the dev. I've reported several bugs related to OSC skinning.
I translate Portuguese for Brazil the PotPlayer on my blog and in PotPlayer Brazil community you will find links, if interested, here the links:
Blog: http://havokdan.wordpress.com/
Google Plus: https://plus.google.com/b/105912245036564277671/105912245036564277671/posts -
Using version 1.5.44465 I can't get subtitles to stay hidden when playing DVD movies, even after making sure "Show Subtitles" is unselected. Can anyone help?
Hi,
using 1.5.44517 I can't see subtitle romanian special carchers (Charset= Easter European ),I only see some ugly squares instead,reverting to 1.5.44465 subtitle is shown fine.
thanks. -
Yes, there are problems in this latest version with accented characters, I received feedback complaining about it and I also had this problem, I'm waiting for the next version, while I'm using the "DirectVobSub" to read subtitles.
↑ SERIOUSLY ↑
LoL, i just had the opposite problem !!! Potplayer couldn't display ALL subtitles, some lines just didnt appear.
Just found out it wos FFdshow and / or Potplayer all along that is causing that !!!
That said, i just don't want to exclude potplayer as possible part of the problem yet !!
Because although latest FFdshow r4527 failed to display all subtitles correct in potplayer, the same problem DID NOT ocure in MPC-HC though !!
Also, check regulary for potplayer changelogs / fixes / Updates!!
Here u are → http://www.dvbsupport.net/info/potplayer.html
cheers, -
Oh, i have found a fix / work arround for this lil nuisance myself long LOOOong time before you suggested that sherpa
Still, i don't think the "benevolent" developers are THAT dedicated to even bother and read my findings!!
Let alone fixing it !!
It seemed to be both FFDshow & potplayer issue ALL together !!!
Yep, TiS an MIXED BAG of hicks & tricks
But ffdshow takes the cake/biscuit regarding that
SERIOUSLeeee
when install stable version install only latest beta update?when add new language???
I know all versions are betas, and PotPlayer does not bring support translations natively, what you do is use a specific application or resource editor to edit the file PotPlayer.dll
If you want both the application, try to contact them to bring developers support the translation or do as the people who translate it into English (I translate from their version, since nothing understand Korean), type in google for type "resource editor" programs or use programs like Radialix, Multilizer, Lingobyte doing this service. -
Hi,I've tested new option to download automatically missing subtitles with version 1.5.45619 beta,but it doesn't work
I've used the Test button and I got the message "Bad URL adress!...",link for the Open Subtitle Database(oSDb) is default : http://www.opensubtitles.org/isdb
thanks.
MKV2AC3 - development thread
By Delta2 in forum Newbie / General discussionsReplies: 216Last Post: 9th Apr 2016, 14:24 -
GfD development version
By borax in forum ProgrammingReplies: 136Last Post: 9th Nov 2011, 17:01 -
Is TSSniper still under development?
By The Realms of Gold in forum EditingReplies: 4Last Post: 29th Apr 2011, 17:33 -
Is ffmpegX still in development?
By reviltihco in forum ffmpegX general discussionReplies: 5Last Post: 13th Aug 2010, 10:54 -
AVI TO AC3 - Development Thread
By freebird73717 in forum AudioReplies: 43Last Post: 2nd Sep 2008, 23:42
