Please make default skins in Light color theme..
I need WindowFrame.dsf in Light so much
P.S I found some on GitHub, but Titlebar on them is always shown.
Skins are located here:
https://github.com/Ingan121/PotPlayerSkins
Looking forward for something to be added in the default PotPlayer install
Results 631 to 660 of 673
Hi,
Is there anyway that I could copy several lines of consecutive subtitle phrases all at once in pot player under windows? I can only copy the subtitle phrase in the current frame. Even if I can select several lines of it in the subtitle browser, I could not find a way to copy them. -
I don't use Potplayer frequently enough to know. But if there is no affirmative answer for you, you might just have to extract the subs to an SRT file, using Subtitle Edit (which is free) or another program. Once you have the SRT file, you can copy whatever you like, as timed text.
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
Thanks. I knew this way but needs opening and searching in the file and finding the exact location in the file. I wanted to do directly inside potplayer since in has built in srt editor and allows to select several lines in it but unfortunately ctr+c does not copy the selected lines. It might be a bug. Is there anyway to contact wit the developer? It is really a great player and enabling this feature makes it more perfect.
Hi, I have recently discovered PotPlayer and am liking it in many ways. I have two usability issues with it at this stage... Firstly, I have a lot of lengthy tutorial videos in m4v format which have "Chapters". One can navigate between chapters using SHIFT-PageUp / PageDown, but there is no way to see what these chapters are named, to simply see a list of Chapters and be able to click on the chapter you want to watch. PLEASE add this to the Playlist view, perhaps something like a check box which enables display of chapters in the current video. Thanks!
[Attachment 87390 - Click to enlarge]
The second thing is an issue with going from Full Screen >> Normal (Reduced) Size to be remembered please! At present, when you go full screen and then resize that window (difficult) it will only remember the reduced size window if you do not close PotPlayer. As soon as you close it and open the same file, it forgets the size and position of the reduced window size, and again you have to perform multiple clicks and drags to get the window back to how you like it. I have not found an option to have this work the way I'd like, perhaps it does exist. See the video showing the issue here
https://videoblurb.com/mp/onecommanderresizeclickmenubar.mp4
Thank you,
Mark -
duplicate post
Last edited by fredphoesh; 14th Jun 2025 at 05:52. Reason: first post not showing, so posted again...
Right new here please be gentle I have a weird issue with Potplayer and RTX VSR, if I use the 13th of March 64 bit version I can play a video and the RTX VSR activates fine and I can see the VSR logo top right to say it's active. If I use any of the newer versions, then the renderer says built in Direct3D11 Video Renderer but the resizer is D3D11 Video Processor.
If I revert by reinstalling to the 250313 64bit version by running the installer without changing any settings then everything is fine again I get the same built in Direct3D11 Video Renderer, but the resizer shows as GPU Super Resolution and as I have the NVidia indicator turned on, I see the small VSR indicator box again.
If I use the MPC Video Renderer, I can get the RTX VSR to activate but then I lose the option to use the D3D11 on screen control for transparent skins features so not ideal.
Anyone have any ideas as I have failed to find a solution to get the native D3D11 Renderer to behave.
Cheers
Nick -
Done a bit more investigating and I can get RTX VSR to activate with the newer versions but only if I put my monitor into HDR mode and also activate RTX HDR as well then Potplayer activates both and I can see both the watermarks top right. So not sure why Potplayer cannot activate just RTX VSR on it's own.
I need help with something that is happening in my Potplayer.
for some reason, When I exit full screen mode, the video screen flickers for a few seconds and sometimes even the command bar at the bottom of the player becomes glitched unless I enter and exit full screen mode again or minimize and restore the program
what is this problem and how do I solve it? -
Any tips how to start my own "playlist" extension (in AngelScript)? Thanks.
Hi!
Was the integral portable mode removed from potplayer? Recently I tried running a second instance in such a way that I added an empty potplayermini.ini file to unpacked installation package. But it crapped into the settings of the local instance, and the ini was deleted. Or do I need to set the main instance to store settings in an ini-file? It's been so long that I played with this that I forgot.
I noticed that for a good while now there's a separate portable package. I never paid attention to it. I tried it after this. It's very repulsive that it asks for admin rights. Which is not only a security risk, but also impairs usability. It's not possible to drag/drop files onto apps in admin mode from normal mode apps. Is this the only option for running in portable mode? -
I run an oil tanker's load of portable apps. You might even say that it's the preferred default here. (That said, I think it's been a long time since I used any portable version of Potplayer.) I've noticed that some fine apps like TeraCopy -- for reasons unknown -- did away with Drag & Drop functionality, after a certain version. I tend to give most apps the Admin rights, unless there's some good reason not to trust them. Some seem to insist on having the Admin rights. This seems to enhance functionality, as best I can determine. Been doing this for a long time, have yet to get bitten by it.
i need help. why is potplayer so bright in comparison to vlc out of the box?
[Attachment 88985 - Click to enlarge] -
when I select video renderer blacks are perfect now but playback is jaggy. any other renderer and Blacks are washed out. also I'm struggling to get pass through audio WorKing, when I select my amp I don't get the notification on the display of the audio stream.
Default sound device should be selected. That way it follows what you're system is set to use.
Washed out colors can also be a GPU setting thing that you need to fix in the driver settings. A full/limited range thing if I remember correctly.
I never used passthrough. I just let the GPU output plain audio via HDMI when I output to the TV. (Never used an amp.) -
HEVC Video is broken in PotPlayer. Here's what I get:
Here's the information about the file:
Here's my HEVC video decoder settings:[Used Filter List]
(1) MPC MP4/MOV Source
(2) Built-in Video Codec/Transform
(3) Enhanced Video Renderer(Custom Present)
(4) Built-in Audio Codec/Transform
(5) DirectSound Audio Renderer
[Video Information]
Codec: HVC1 - Native D3D9 DXVA VLD Decoder - AMD Radeon Pro 5500M
Input type: HVC1(24 bits)
Input size: 720 × 1280(1:0.56)
Output type: dxva
Output size: 720 × 1280(1:0.56)
Frame rate: 23.976
BitRate: Unknown
[Audio Information]
Codec: AAC(0xaac0) - Built-in FFmpeg Decoder(aac)
Sample rate: 48000 -> 48000 samples/sec
Bits per sample: 16 -> 16 bits/sample
Channels: 2 -> 2 channels
Bitrate: 125 kbps
[Attachment 91157 - Click to enlarge]
I downloaded HEVC video extensions from here: https://en.potplayer.org/hevc-video-extensions.html
After I downloaded it, other players like the default Windows media players started to play the video correctly but not the PotPlayer.
Update. After I selected the FFmpeg.dll and installed the HEVC video extensions, the video started to play correctly in PotPlayer, too.Last edited by KulaGGin; 11th Feb 2026 at 11:42.
[deleted because I made a new thread, because the issue is getting more complex]
Last edited by timer; 11th Mar 2026 at 11:03. Reason: Made a new thread because issue is more complex
If MP4 has dropped frames then potplayer internal clock also skip e.g. 5 frames dropped consequently then clock inside potplayer switch 5 frames ahead and .srt subtitles that are set up to show per frame timestamps also shift 5 subtitles ahead as result video has 5022 frames subtitles have 5022 frames and because of all skipped frames subtitles end earlier than video end.
Please provide solution -
OpenCodec installer was updated (v5)
https://t1.daumcdn.net/potplayer/PotPlayer/Codec/v5/OpenCodecSetup64.exe
This is for PotPlayer x64, it can be extracted using 7-Zip if you want to check the files inside, or don't want to use the installer, just copy the "Module" folder to the root of the PotPlayer folder.
Alternative link:
https://t1.kakaocdn.net/potplayer/PotPlayer/Codec/v5/OpenCodecSetup64.exeLast edited by Gus.Ghanem; 9th Jul 2026 at 10:26.
I think videohelp should update their opencodec link to what you put there Gus.Ghanem and they haven't as it is version 4 and not version 5. There is new codec that people can try with videohelp if they want to test out dolby digital plus atmos joc decoding. Keep in mind it's more in early development but might have promise in the near future. I feel it takes better computer to run it properly but in due time with proper optimizations should run better over time. I think Omniphony with MPV-Omniphony using Harletty-bridge works better to decode Atmos in TrueHD and Dolby Digital Plus extensions.
https://github.com/chyinan/OpenJOC
https://github.com/chyinan/OpenJOC/releases
https://github.com/chyinan/OpenJOC/releases/download/v0.18.0/openjoc-lav-0.18.0-windows-x64.zip
mpv version below if you want to test it and see how it works and such
https://github.com/chyinan/OpenJOC/releases/download/v0.18.0/openjoc-mpv-0.18.0-windows-x64.zip
It is essentially a fork patch version of LAV Filters for directshow to decode atmos which can be used with potplayer. instructions in link below if you want to see if it works well enough. I think it sounds interesting but needs more work done to sound good and correct. You can use movies & tv application on windows 10/11 as long as you have the microsoft dolby mft dll that allows atmos decoding if you want to compare. There's a lot of work being done on atmos, auro3d, dts
decoding these days, especially with AI-assisted help such as Claude AI or ChatGPT Codex.
https://github.com/chyinan/OpenJOC/blob/master/docs/site/using/windows-lav-potplayer.md
MKV2AC3 - development thread
By Delta2 in forum Newbie / General discussionsReplies: 216Last Post: 9th Apr 2016, 15:24 -
GfD development version
By borax in forum ProgrammingReplies: 136Last Post: 9th Nov 2011, 18:01 -
Is TSSniper still under development?
By The Realms of Gold in forum EditingReplies: 4Last Post: 29th Apr 2011, 18:33 -
Is ffmpegX still in development?
By reviltihco in forum ffmpegX general discussionReplies: 5Last Post: 13th Aug 2010, 11:54 -
AVI TO AC3 - Development Thread
By freebird73717 in forum AudioReplies: 43Last Post: 3rd Sep 2008, 00:42
Quote![Computer details: [This list is SELDOM up-to-date !]
Shuttle SX48P2, Q9550, 4Gb.
ATI Radeon 45__ (?)
Win-7 Ent. x86
WD Black 500Gb. + 1Tb.
Shuttle SP35P2 Pro,
Intel Xeon 3230, 8Gb.
ATI FireGL V3400
Win-7 Ultimate x64
Shuttle SH67H3 (i5)
w/ 16 GB. RAM &
Win-10 Pro
SSD + HDD
LG Blu-Ray burner
[acquired used as an already-HTPC,
though not yet assigned to that task]
Shuttle SH67H3 (i7)
w/ similar config to the one above
and others
[also (reluctantly) perform some "IT-by-default"
services for an office, with other computers
there . . . ]
Various older model Lenovo laptops, like T-40
series, T-60
IPAD Pro (Gen. 2)
Video Gear includes:
Oppo 95-BR
Pioneer 520, 640, 460
Toshiba 32HL67
Panasonic G-25 plasma
Pan V-series 58 plasma.
TBC-1000 & other assorted gizmos
Panasonic 4820-SVHS
& various other VCRs
Various Betamax gear
Var. video streaming boxes Comp](/images/buttons/computer.gif)
