I am trying to convert a DVD with 2 audio streams to an MKV. I have found that Xmedia Recode to be the best program for my use although I'm having difficulty in achieving the results I want. When I convert the video any fast action on the converted MKV has horizontal lines across it. I have tried various video options such Rate Control Mode and Bitrate but I'm not having much look. The converted MKV looks really good when there is little camera movement however the video I want to convert is very fast paced.
I'm not too bothered about file size. The original DVD is about 45 mins and 2.2Gb. I'm happy for the MKV to be between 1 and 2 Gb.
Can anybody recommend some setting to achieve a smooth video, preferably in Xmedia Recode?
It's probably interlaced so you must then deinterlace. Check under filters in xmedia recode.
Thanks that's certainly helped.
Should I pick any particular setting? I have Linear Blending, Linear Interpolation, Cubic Interpolation and Medion.
I now have a new problem. All of the video's I have converted are missing the end by 5-10 minutes.
Trouble with Xmedia Recode MKV->MP4 with DTS audio
By biodtl in forum Video ConversionReplies: 1Last Post: 20th Sep 2012, 16:31 -
Convert miniDV to h.264 using XMedia Recode. Fast moves are very ugly...
By marqus in forum Video ConversionReplies: 3Last Post: 15th May 2011, 05:53 -
Xmedia Recode Crashing when converting to MKV
By Des in forum DVD RippingReplies: 4Last Post: 30th Dec 2010, 10:37 -
Xmedia Recode V. 2.25.8
By pepegot1 in forum Video ConversionReplies: 20Last Post: 30th Aug 2010, 00:58 -
XMedia Recode v2.2.2.0 DVD->MKV (H264AVC+AC3) Ms Visual C++ Runtime Error
By Bonie81 in forum DVD RippingReplies: 2Last Post: 13th May 2010, 12:32
