Just got a Hercules AIW7500 Radeon card. I'm trying to set up VirtualDub to try capturing, but it seems a different version to the one in the help file.
I'm trying to set it up to use the tv tuner. I can find the option to search for channels, but it doesn;t save them, and I have to go trhough manually to select a channel (1 to 60 odd!) Is there anything I can do to automatically shows all available channels?
Thanks.
use the multi media centre to tune and select your channels. The next time you open vdub it should be set to the last channel you selected in mmc
Craig
Best PQ as possible via external tuner? Bypassing internal tuner/processor.
By Wizard256 in forum Capturing and VCRReplies: 0Last Post: 24th Jan 2010, 23:39 -
VDub Help..!!
By scratchlikeme in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2009, 07:40 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 02:42 -
TV Tuner Help!
By anony283 in forum Capturing and VCRReplies: 13Last Post: 30th Apr 2008, 10:30 -
High Definition TV? Tuner or no Tuner?
By aturjans in forum DVB / IPTVReplies: 6Last Post: 17th Mar 2008, 08:31
