Results 151 to 165 of 165
I have captured with both Hauppauge Capture and Capture4Me. Same results.
I've tried changing file type (MP4/TS) with the same results.
It's not the box because I've captured OTA stuff just fine (which I don't need this box for). However, the PS3 and the Roku completely throws it for a loop. It goes nuts.
Here is the error log for a movie that I just capped from the Roku.
Sometimes the errors will look like this:MPEG2Repair: J:\_TEMP\File.ts
Sequence Frame 13779(0-X) / Time 0:07:37 :
Error: Packet 4540062 has no TS Sync Byte.
VideoWarning: Discontinuity of (7+) packet(s). First packet ending at offset 853541104
VideoWarning: Discontinuity of (13+) packet(s). First packet ending at offset 853542420
AudioError: Corrupted AC3 frame of 2454 payload bytes at file offset 853509878
AudioWarning: Timestamp gap of 8.767867 sec. ending at file offset 853509878
Sequence Frame 31805(0-X) / Time 0:17:50 :
Error: Packet 10480830 has no TS Sync Byte.
VideoWarning: Discontinuity of (1+) packet(s). First packet ending at offset 1970405592
VideoWarning: Discontinuity of (7+) packet(s). First packet ending at offset 1970409540
Sequence Frame 31807(0-X) / Time 0:17:50 :
AudioError: Corrupted AC3 frame of 2150 payload bytes at file offset 1970394802
AudioWarning: Timestamp gap of 12.895800 sec. ending at file offset 1970394802
Sequence Frame 49833(0-X) / Time 0:28:02 :
Error: Packet 16421598 has no TS Sync Byte.
VideoWarning: Discontinuity of (6+) packet(s). First packet ending at offset 3087270024
VideoWarning: Discontinuity of (3+) packet(s). First packet ending at offset 3087272280
Sequence Frame 49836(0-X) / Time 0:28:02 :
AudioError: Corrupted AC3 frame of 2702 payload bytes at file offset 3087249890
AudioWarning: Timestamp gap of 12.095822 sec. ending at file offset 3087249890
Sequence Frame 67862(0-X) / Time 0:38:17 :
VideoWarning: Discontinuity of (3+) packet(s). First packet ending at offset 4204200020
VideoWarning: Discontinuity of (1+) packet(s). First packet ending at offset 4204203216
AudioError: Corrupted AC3 frame of 1902 payload bytes at file offset 4204166586
AudioWarning: Timestamp gap of 11.615822 sec. ending at file offset 4204166586
Sequence Frame 85883(0-X) / Time 0:48:28 :
Error: Packet 28303484 has no TS Sync Byte.
VideoWarning: Discontinuity of (7+) packet(s). First packet ending at offset 5321064752
VideoWarning: Discontinuity of (9+) packet(s). First packet ending at offset 5321069264
Sequence Frame 85884(0-X) / Time 0:48:28 :
AudioError: Corrupted AC3 frame of 2886 payload bytes at file offset 5321041498
AudioWarning: Timestamp gap of 12.063822 sec. ending at file offset 5321041498
Sequence Frame 103914(0-X) / Time 0:58:44 :
Error: Packet 34244600 has no TS Sync Byte.
VideoWarning: Discontinuity of (14+) packet(s). First packet ending at offset 6437994736
VideoWarning: Discontinuity of (14+) packet(s). First packet ending at offset 6438006580
Sequence Frame 103917(0-X) / Time 0:58:44 :
AudioError: Corrupted AC3 frame of 2430 payload bytes at file offset 6437968834
AudioWarning: Timestamp gap of 11.103822 sec. ending at file offset 6437968834
Sequence Frame 121941(0-X) / Time 1:08:54 :
Error: Packet 40185368 has no TS Sync Byte.
VideoWarning: Discontinuity of (8+) packet(s). First packet ending at offset 7554859204
VideoWarning: Discontinuity of (15+) packet(s). First packet ending at offset 7554860896
AudioWarning: Timestamp gap of 11.999800 sec. ending at file offset 7554802186
Sequence Frame 139967(0-X) / Time 1:19:10 :
Error: Packet 46126136 has no TS Sync Byte.
VideoWarning: Discontinuity of (14+) packet(s). First packet ending at offset 8671723692
Sequence Frame 139968(0-X) / Time 1:19:10 :
VideoWarning: Discontinuity of (6+) packet(s). First packet ending at offset 8671735912
Sequence Frame 139969(0-X) / Time 1:19:10 :
AudioError: Corrupted AC3 frame of 1694 payload bytes at file offset 8671719858
AudioWarning: Timestamp gap of 11.231822 sec. ending at file offset 8671719858
Sequence Frame 157991(0-X) / Time 1:29:20 :
Error: Packet 52066905 has no TS Sync Byte.
VideoWarning: Discontinuity of (3+) packet(s). First packet ending at offset 9788588416
VideoWarning: Discontinuity of (7+) packet(s). First packet ending at offset 9788604020
Sequence Frame 157994(0-X) / Time 1:29:20 :
AudioError: Corrupted AC3 frame of 2798 payload bytes at file offset 9788548626
AudioWarning: Timestamp gap of 11.711800 sec. ending at file offset 9788548626
Sequence Frame 176019(0-X) / Time 1:39:36 :
Error: Packet 58008021 has no TS Sync Byte.
VideoWarning: Discontinuity of (14+) packet(s). First packet ending at offset 10905518324
VideoWarning: Discontinuity of (2+) packet(s). First packet ending at offset 10905525844
AudioError: Corrupted AC3 frame of 2982 payload bytes at file offset 10905477834
AudioWarning: Timestamp gap of 11.071822 sec. ending at file offset 10905477834
Sequence Frame 194043(0-X) / Time 1:49:46 :
Error: Packet 63948789 has no TS Sync Byte.
VideoWarning: Discontinuity of (10+) packet(s). First packet ending at offset 12022382876
VideoWarning: Discontinuity of (10+) packet(s). First packet ending at offset 12022387952
AudioError: Corrupted AC3 frame of 2542 payload bytes at file offset 12022331226
AudioWarning: Timestamp gap of 10.751822 sec. ending at file offset 12022331226
Sequence Summary:
File Size Processed: 12.28 GB, Play Time: 01h:55m:36s
30.70 FPS (Average), 14.34 Mbps (Average).
AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 384 kbps.
Dialog Normalization: -31.0 dB, Center Mix Level: -3.0 dB, Surround Mix Level: -3.0 dB
10 of 216777 audio frames found with errors.
125.310024 seconds of audio timestamp gaps.
End of Log
Sometimes the video will just completely stop and the audio will keep playing. Sometimes both will stop.
It's just a mess and I'm REALLY frustrated
What Input is it Component or HDMI ?.
Audio is Optical Audio or HDMI ?.
If HDMI do you have HDMI splitter in the mix ?. -
HDMI
And, yes, there's a splitter to remove the HDCP.
HOWEVER, before you go blaming the splitter, I tried running the OTA signal through the splitter first and then sending the signal to the box. There was no issue with the OTA recordings.
Now, unless there are glitches with the box removing the HDCP, then that's an entirely different issue. I would think it either works or it doesn't.
That what I was thinking a HDCP may be the root cuase, keep in mind with HDCP the handshake is alway happing.
Do have problem recording from PS3 ?.
What splitter box do you have make model ?. -
I only tried doing it once from the PS3 but it only showed one glitch. I haven't had the time to re-watch the material (it's a movie that's 2 hours long) to make sure it was catching all glitches. If there are any others, they're certainly not as severe. With the PS3, you can download movies to the hard drive and play them off of that whereas the Roku is just streaming. I have no idea if that would make a difference.
The splitter box is the ViewHD 2 Port 1x2 Powered HDMI Mini Splitter for 1080P & 3D | VHD-1X2MN3D. Are there any others that remove HDCP more reliably?Last edited by digitalfreaknyc; 6th Nov 2015 at 14:00.
The VHD-1X2MN3D reliably removes HDCP.
Power-cycling the HD-PVR2 and the splitter might help. (All of Hauppauges HD-PVR products need power cycling on a regular basis, if you are not already doing that.)
That said, it may be the streaming video itself. I would sometimes get gltchy captures using my HD-PVR Colossus, which I attributed to transmission errors in the audio or video stream delivered to my cable box. I could sometimes see or hear them them while simply watching a channel with the cable box connected directly to the TV.
[Edit]Also, it is not a good idea to post the about the same problems in multiple threads. It is against the forum rules, and confusing to follow.Last edited by usually_quiet; 6th Nov 2015 at 15:24.
I never have problems watching it normally through the Roku. Ever. Like I said, it's pretty rock solid and my internet connection is so reliable and my speed is so high that it shouldn't be much of a problem.
And, again, power-cycling shouldn't be an issue because, like I said, it works fine with the OTA signal. No errors whatsoever.
I did one test with the PS3 and it was better...but still had glitches.
The Roku was the worst. Constant problems. So it would seem that the source is a part of the issue but why, if they play back perfectly fine, is the splitter/Hauppauge combo introducing issues?
I'm really perplexed.
Oh crap. I didn't know that.
Thanks for telling me.
OK I've now captured the exact SAME movie 3 times and THIS is really odd: all of the errors that are happening are happening within a minute of each other. I'm quoting the error files below. My THEORY is that the errors are coming from those stupid TEMP.ts files that the hauppauge makes, for some reason. My old 1212 didn't make those and I have no issues with it. Could that be the case? Check it out!
MPEG2Repair: J:\_TEMP\fRANKIE.ts
Sequence Frame 33493(0-X) / Time 0:18:33 :
Error: Packet 11246733 has no TS Sync Byte.
VideoWarning: Discontinuity of (4+) packet(s). First packet ending at offset 2114388340
Sequence Frame 33494(0-X) / Time 0:18:33 :
VideoWarning: Discontinuity of (14+) packet(s). First packet ending at offset 2114391348
AudioError: Corrupted AC3 frame of 3294 payload bytes at file offset 2114370418
AudioWarning: Timestamp gap of 13.760022 sec. ending at file offset 2114370418
Sequence Frame 51519(0-X) / Time 0:28:48 :
Error: Packet 17300446 has no TS Sync Byte.
VideoWarning: Discontinuity of (2+) packet(s). First packet ending at offset 3252486440
VideoWarning: Discontinuity of (9+) packet(s). First packet ending at offset 3252486628
AudioError: Corrupted AC3 frame of 3270 payload bytes at file offset 3252475134
AudioWarning: Timestamp gap of 15.456022 sec. ending at file offset 3252475134
Sequence Frame 69548(0-X) / Time 0:39:05 :
Error: Packet 23353811 has no TS Sync Byte.
VideoWarning: Discontinuity of (4+) packet(s). First packet ending at offset 4390519080
VideoWarning: Discontinuity of (10+) packet(s). First packet ending at offset 4390521524
Sequence Frame 69550(0-X) / Time 0:39:25 :
AudioError: Corrupted AC3 frame of 2742 payload bytes at file offset 4390502358
AudioWarning: Timestamp gap of 15.520022 sec. ending at file offset 4390502358
Sequence Frame 87576(0-X) / Time 0:49:26 :
Error: Packet 29407873 has no TS Sync Byte.
VideoWarning: Discontinuity of (13+) packet(s). First packet ending at offset 5528682892
VideoWarning: Discontinuity of (15+) packet(s). First packet ending at offset 5528683456
Sequence Frame 87578(0-X) / Time 0:49:26 :
AudioError: Corrupted AC3 frame of 3478 payload bytes at file offset 5528663966
AudioWarning: Timestamp gap of 11.648022 sec. ending at file offset 5528663966
Sequence Frame 105603(0-X) / Time 0:59:39 :
Error: Packet 35461586 has no TS Sync Byte.
VideoWarning: Discontinuity of (14+) packet(s). First packet ending at offset 6666781084
VideoWarning: Discontinuity of (2+) packet(s). First packet ending at offset 6666781648
Sequence Frame 105605(0-X) / Time 0:59:39 :
AudioError: Corrupted AC3 frame of 2558 payload bytes at file offset 6666759346
AudioWarning: Timestamp gap of 9.664022 sec. ending at file offset 6666759346
Sequence Frame 123625(0-X) / Time 1:09:50 :
VideoWarning: Discontinuity of (8+) packet(s). First packet ending at offset 7804879128
Sequence Frame 123626(0-X) / Time 1:09:50 :
VideoWarning: Discontinuity of (4+) packet(s). First packet ending at offset 7804887212
AudioError: Corrupted AC3 frame of 4374 payload bytes at file offset 7804842310
AudioWarning: Timestamp gap of 9.792022 sec. ending at file offset 7804842310
Sequence Frame 141655(0-X) / Time 1:20:02 :
Error: Packet 47569012 has no TS Sync Byte.
VideoWarning: Discontinuity of (10+) packet(s). First packet ending at offset 8942977336
Sequence Frame 141656(0-X) / Time 1:20:02 :
VideoWarning: Discontinuity of (14+) packet(s). First packet ending at offset 8942985608
Sequence Frame 141657(0-X) / Time 1:20:02 :
AudioError: Corrupted AC3 frame of 2718 payload bytes at file offset 8942974382
AudioWarning: Timestamp gap of 8.736000 sec. ending at file offset 8942974382
Sequence Frame 159687(0-X) / Time 1:30:12 :
Error: Packet 53623074 has no TS Sync Byte.
VideoWarning: Discontinuity of (3+) packet(s). First packet ending at offset 10081141072
VideoWarning: Discontinuity of (15+) packet(s). First packet ending at offset 10081141260
AudioError: Corrupted AC3 frame of 3486 payload bytes at file offset 10081084058
AudioWarning: Timestamp gap of 11.616022 sec. ending at file offset 10081084058
Sequence Frame 177712(0-X) / Time 1:40:25 :
Error: Packet 59677136 has no TS Sync Byte.
VideoWarning: Discontinuity of (14+) packet(s). First packet ending at offset 11219304836
VideoWarning: Discontinuity of (3+) packet(s). First packet ending at offset 11219307844
Sequence Frame 177714(0-X) / Time 1:40:25 :
AudioError: Corrupted AC3 frame of 2726 payload bytes at file offset 11219302690
AudioWarning: Timestamp gap of 9.568022 sec. ending at file offset 11219302690
Sequence Frame 195739(0-X) / Time 1:50:36 :
Error: Packet 65730500 has no TS Sync Byte.
VideoWarning: Discontinuity of (10+) packet(s). First packet ending at offset 12357337452
VideoWarning: Discontinuity of (1+) packet(s). First packet ending at offset 12357339332
AudioError: Corrupted AC3 frame of 2934 payload bytes at file offset 12357285598
AudioWarning: Timestamp gap of 9.600022 sec. ending at file offset 12357285598
Sequence Frame 213777(0-X) / Time 2:00:47 :
Error: Packet 71784213 has no TS Sync Byte.
VideoWarning: Discontinuity of (11+) packet(s). First packet ending at offset 13495435528
VideoWarning: Discontinuity of (5+) packet(s). First packet ending at offset 13495435904
Sequence Frame 213778(0-X) / Time 2:00:47 :
AudioError: Corrupted AC3 frame of 4582 payload bytes at file offset 13495392850
AudioWarning: Timestamp gap of 12.800000 sec. ending at file offset 13495392850
Sequence Frame 228335(0-X) / Time 2:09:05 :
Info: End of H.264 sequence
Sequence Summary:
File Size Processed: 13.42 GB, Play Time: 02h:06m:58s
29.97 FPS (Average), 14.00 Mbps (Average).
AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 640 kbps.
11 of 238070 audio frames found with errors.
128.160201 seconds of audio timestamp gaps.
End of LogMPEG2Repair: J:\_TEMP\Frankie new.ts
Sequence Frame 13376(0-X) / Time 0:07:24 :
Error: Packet 4492783 has no TS Sync Byte.
VideoWarning: Discontinuity of (2+) packet(s). First packet ending at offset 844693904
VideoWarning: Discontinuity of (10+) packet(s). First packet ending at offset 844705748
Sequence Frame 13377(0-X) / Time 0:07:24 :
AudioError: Corrupted AC3 frame of 5110 payload bytes at file offset 844642566
AudioWarning: Timestamp gap of 8.448022 sec. ending at file offset 844642566
Sequence Frame 31401(0-X) / Time 0:17:34 :
Error: Packet 10546496 has no TS Sync Byte.
VideoWarning: Discontinuity of (10+) packet(s). First packet ending at offset 1982791984
VideoWarning: Discontinuity of (10+) packet(s). First packet ending at offset 1982801196
AudioError: Corrupted AC3 frame of 2718 payload bytes at file offset 1982790850
AudioWarning: Timestamp gap of 12.960022 sec. ending at file offset 1982790850
Sequence Frame 49429(0-X) / Time 0:27:48 :
Error: Packet 16599861 has no TS Sync Byte.
VideoWarning: Discontinuity of (11+) packet(s). First packet ending at offset 3120824616
VideoWarning: Discontinuity of (2+) packet(s). First packet ending at offset 3120825744
AudioError: Corrupted AC3 frame of 4014 payload bytes at file offset 3120822002
AudioWarning: Timestamp gap of 11.936022 sec. ending at file offset 3120822002
Sequence Frame 67457(0-X) / Time 0:38:02 :
Error: Packet 22653226 has no TS Sync Byte.
VideoWarning: Discontinuity of (12+) packet(s). First packet ending at offset 4258857372
VideoWarning: Discontinuity of (3+) packet(s). First packet ending at offset 4258857748
Sequence Frame 67458(0-X) / Time 0:38:02 :
AudioError: Corrupted AC3 frame of 4214 payload bytes at file offset 4258814966
AudioWarning: Timestamp gap of 12.416022 sec. ending at file offset 4258814966
Sequence Frame 85482(0-X) / Time 0:48:15 :
Error: Packet 28707288 has no TS Sync Byte.
VideoWarning: Discontinuity of (4+) packet(s). First packet ending at offset 5397021128
VideoWarning: Discontinuity of (15+) packet(s). First packet ending at offset 5397021316
Sequence Frame 85483(0-X) / Time 0:48:15 :
AudioError: Corrupted AC3 frame of 3662 payload bytes at file offset 5396991918
AudioWarning: Timestamp gap of 12.480022 sec. ending at file offset 5396991918
Sequence Frame 103509(0-X) / Time 0:58:29 :
Error: Packet 34761001 has no TS Sync Byte.
VideoWarning: Discontinuity of (14+) packet(s). First packet ending at offset 6535120188
Sequence Frame 103512(0-X) / Time 0:58:29 :
AudioError: Corrupted AC3 frame of 4566 payload bytes at file offset 6535114126
AudioWarning: Timestamp gap of 11.456000 sec. ending at file offset 6535114126
Sequence Frame 121537(0-X) / Time 1:08:42 :
Error: Packet 40814714 has no TS Sync Byte.
VideoWarning: Discontinuity of (12+) packet(s). First packet ending at offset 7673217304
VideoWarning: Discontinuity of (2+) packet(s). First packet ending at offset 7673217868
Sequence Frame 121538(0-X) / Time 1:08:42 :
AudioError: Corrupted AC3 frame of 4014 payload bytes at file offset 7673189874
AudioWarning: Timestamp gap of 11.936022 sec. ending at file offset 7673189874
Sequence Frame 139565(0-X) / Time 1:18:55 :
Error: Packet 46868776 has no TS Sync Byte.
VideoWarning: Discontinuity of (12+) packet(s). First packet ending at offset 8811381060
VideoWarning: Discontinuity of (7+) packet(s). First packet ending at offset 8811383128
AudioError: Corrupted AC3 frame of 2934 payload bytes at file offset 8811318574
AudioWarning: Timestamp gap of 12.480022 sec. ending at file offset 8811318574
Sequence Frame 157589(0-X) / Time 1:29:09 :
VideoWarning: Discontinuity of (1+) packet(s). First packet ending at offset 9949479104
VideoWarning: Discontinuity of (8+) packet(s). First packet ending at offset 9949480796
Sequence Frame 157592(0-X) / Time 1:29:09 :
AudioError: Corrupted AC3 frame of 4014 payload bytes at file offset 9949475374
AudioWarning: Timestamp gap of 8.160022 sec. ending at file offset 9949475374
Sequence Frame 175619(0-X) / Time 1:39:19 :
Error: Packet 58976203 has no TS Sync Byte.
VideoWarning: Discontinuity of (6+) packet(s). First packet ending at offset 11087577480
VideoWarning: Discontinuity of (11+) packet(s). First packet ending at offset 11087578608
Sequence Frame 175620(0-X) / Time 1:39:19 :
AudioError: Corrupted AC3 frame of 4214 payload bytes at file offset 11087537886
AudioWarning: Timestamp gap of 11.136022 sec. ending at file offset 11087537886
Sequence Frame 193647(0-X) / Time 1:49:31 :
Error: Packet 65029916 has no TS Sync Byte.
VideoWarning: Discontinuity of (10+) packet(s). First packet ending at offset 12225675572
Sequence Frame 193650(0-X) / Time 1:49:31 :
AudioError: Corrupted AC3 frame of 4750 payload bytes at file offset 12225653182
AudioWarning: Timestamp gap of 11.872022 sec. ending at file offset 12225653182
Sequence Frame 210699(0-X) / Time 1:59:13 :
Sequence Summary:
File Size Processed: 12.39 GB, Play Time: 01h:57m:10s
11 of 219689 audio frames found with errors.
125.280224 seconds of audio timestamp gaps.
End of Log -
Does mpeg2 repair work well with these files? Are they able to correct some of the errors?
digitalfreaknyc
I think you best beat is get hold some in Hauppauge Tech Support (Software/Hardware Engineering) -
Hauppauge HD PVR
By Susan_T in forum Video Streaming DownloadingReplies: 1Last Post: 21st Nov 2011, 21:06 -
Hauppauge HD PVR
By Susan_T in forum Newbie / General discussionsReplies: 1Last Post: 21st Nov 2011, 16:20 -
Hauppauge hd pvr sound issues with new graphics card
By Mitterhouse in forum Capturing and VCRReplies: 2Last Post: 27th Mar 2011, 18:26 -
hauppauge hd pvr 1212 Capture Issues
By jwack in forum Capturing and VCRReplies: 10Last Post: 19th Nov 2009, 21:17 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 10:04
