I`m trying to get smartripper 2.41 to rip a dvd giving out the m2v and ac3 file. I can only get it to give out the vob and the ac3 file.
What am I doing wrong?
As far as I know you can only rip vob files from the DVD with
smartripper
but after that you can split the vob files in AC3 en MPEG files using vstrip
gr,
Bart. -
Or you can use DVD2AVI to convert the VOB files. Or if you have the MPG2 license installed you could try using DVD2SVCD and make a direct convert to MPG2 SVCD.
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26
