Hi,
i have some 720p50 mpeg2 video records from my sat-reciver. The movie is aired on 1280x720@50p. The movie itself is an 25p but every frame twice. It's 25p stretched to 50p. I don't know how to describe it the best way. I can see it when i jump frame by frame.
Because the movie has black bars on top and bottom i want to reencode it to save space.
and think i can also save space by skipping every 2nd useless frame. I'd like to use Handbreak if it is possible. I tried to change the framerate in handbreak but the file size didn't changed.
is it possible to skip every 2nd frame in handbreak?
thanks for your help and greets....
I don't use Handbrake but did you actually get it down to 25fps with the same length? That is, was every other frame removed?
Didn't change from what? From the size of the source video? That entirely depends on the bitrate used. You want a smaller size? Use a lower bitrate.I tried to change the framerate in handbreak but the file size didn't changed. -
As you found out, a change of frame-rate does not change the file-size. Neither will it change by cropping any black-bars.
File-size = bitrate*run-length. So you only reduce the file-size by reducing the bit-rate.
1080/50p mts to 720/50p mp4 or 1080/25p
By glenpinn in forum Video ConversionReplies: 5Last Post: 5th Feb 2013, 08:42 -
convert 50p and 59.94p 264 to 1080 25i and 1080 29.97i
By wiseant in forum Video ConversionReplies: 8Last Post: 13th Aug 2012, 17:02 -
Need to convert 23,976 1080p to 25p PAL DVD
By JMantis in forum Video ConversionReplies: 8Last Post: 12th Apr 2012, 17:22 -
Premiere Pro convert settings 50i to 25p
By jall in forum Video ConversionReplies: 5Last Post: 6th Jan 2010, 03:05 -
50p to 25p
By tinkyawoo in forum EditingReplies: 9Last Post: 28th Jul 2008, 13:43
