Greetings, VH Community.
May I ask you who have tried out those converters mentioned in the first post of the Sticky:
Which of those could convert a video (V_MPEG4/ISO/AVC) in an mkv container, and hardsubbing the subtitle (.ASS) residing in the file without messing the style of the substitle? I want to watch those videos off a flashdrive on a DivX player (.AVI), meaning the ones like Handbrake are out of question.
Below are what I've tried so far:
-AVS Video Converter 6.3
(Really slow, produce white texts only, line placement kept intact except styling is forced to a simple one—no complicated subs)
-Aimersoft Video Converter Ultimate 4.2
(Quite fast, supports coloured texts, styling varies but original styling is lost which includes the line placement)
-Freemake Video Converter 3.2
(Similar to AVS but at least not as slow) {The developers are currently considering to keep the styling intact}
*Video to Video Converter 2.9
(Does not support "hidden" softsub; same thing with Xilisoft's)
I tried downloading Format Factory countless times, but my Anti-Virus (ESET) keep warning it as a potentially harmful object. A user told me that it does not change the style of the original softsub. Is that true?
I also tried the other approach: extracting the text file and then hardsubbing it manually. The problem: I'll have to convert the subtitle file into .SRT i.e. losing style. Not to mention how time-consuming it would be when dealing with tons of video files.
Regards,
Kazuyuki.
負けるわけにはいかない!
The best method is to use avisynth with the vsfilter plugin.
See http://forum.aegisub.org/viewtopic.php?f=5&t=2468 . And instead of using megui can you try open the avisynth avs file with for example xvid4psp 5 and use avi xvid dvd player preset. -
I see. I was also curious about this approach but creating the script for each file seemed to be a daunting task.
Well, I guess beggars can't be choosers.
Thank you for the links.
Regards,
Kazuyuki.
Nero Recode 2 Chapter Mark "Creep" vs. Original DVD
By CobraPilot in forum DVD RippingReplies: 4Last Post: 16th Feb 2012, 23:29 -
Changing The Audio Of An AVI File "Language" {HELP COMPLICATED PROBLEM}
By Mr CMTS in forum EditingReplies: 1Last Post: 28th Nov 2011, 20:04 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
How to reduce "striped gradients" in too-compressed videos?
By Greycat in forum RestorationReplies: 9Last Post: 24th Jun 2010, 16:43 -
Making videos "for sure" playable in standalone player
By Meagain in forum Video ConversionReplies: 1Last Post: 29th Dec 2008, 17:39
