Trying to use ffmpeg to convert a short avi clip.
Two different clips with XviD and Huffy video and mp3 CBR audio.
The result is the error message and a zero sized file.
The same clips convert OK using Nero, x264, mp4box.
Any ideas what I'm doing wrong?
Command lines:
Audio:
-i - "%(tempaudiofile)" -vn -f ac3_fixed -ar %(samplingrate) -ac %(channels) -ab 192k
Video:
-f rawvideo -s %(width)x%(height) -r %(fpsnum)/%(fpsden) -i - -vcodec mpeg2video -bf 2 -b 3000k "%(tempvideofile)"
Muxer:
-i "%(tempvideofile)" -i "%(tempaudiofile)" -acodec copy -vcodec copy "%(outputname)"
Error log:[*] AVI: Opening file "C:\Users\Superuser\Desktop\clip_german.avi"[*] Beginning dub operation.
[i] Dub: Input (decompression) format is: YUYV.
[i] Dub: Output (compression) format is: YUV420.
[i] VideoEnc: ffmpeg version N-50171-gb16bf91 Copyright (c) 2000-2013 the
FFmpeg developers
[i] VideoEnc: built on Feb 22 2013 01:06:51 with gcc 4.7.2 (GCC)
[i] VideoEnc: configuration: --enable-gpl --enable-version3
--disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig
--enable-frei0r --enable-gnutls --enable-libass --enable-libbluray
--enable-libcaca --enable-libfreetype --enable-libgsm --enable-libmp3lame
--enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg
--enable-libopus --enable-librtmp --enable-libschroedinger
--enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame
--enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid
--enable-zlib
[i] VideoEnc: libavutil 52. 17.102 / 52. 17.102
[i] VideoEnc: libavcodec 54. 92.100 / 54. 92.100
[i] VideoEnc: libavformat 54. 63.100 / 54. 63.100
[i] VideoEnc: libavdevice 54. 3.103 / 54. 3.103
[i] VideoEnc: libavfilter 3. 39.100 / 3. 39.100
[i] VideoEnc: libswscale 2. 2.100 / 2. 2.100
[i] AudioEnc: ffmpeg version N-50171-gb16bf91 Copyright (c) 2000-2013 the
FFmpeg developers
[i] AudioEnc: built on Feb 22 2013 01:06:51 with gcc 4.7.2 (GCC)
[i] AudioEnc: configuration: --enable-gpl --enable-version3
--enable-zlib
[i] AudioEnc: libavutil 52. 17.102 / 52. 17.102
[i] AudioEnc: libavcodec 54. 92.100 / 54. 92.100
[i] AudioEnc: libavformat 54. 63.100 / 54. 63.100
[i] AudioEnc: libavdevice 54. 3.103 / 54. 3.103
[i] AudioEnc: libavfilter 3. 39.100 / 3. 39.100
[i] AudioEnc: libswscale 2. 2.100 / 2. 2.100
[i] AudioEnc: libswresample 0. 17.102 / 0. 17.102
[i] VideoEnc: libswresample 0. 17.102 / 0. 17.102
[i] VideoEnc: libpostproc 52. 2.100 / 52. 2.100
[i] VideoEnc: [rawvideo @ 020f9fe0] Estimating duration from bitrate, this may
be inaccurate
[i] VideoEnc: Input #0, rawvideo, from 'pipe:':
[i] VideoEnc: Duration: N/A, start: 0.000000, bitrate: 69120 kb/s
[i] VideoEnc: Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p,
640x360, 69120 kb/s, 25 tbr, 25 tbn, 25 tbc
[i] VideoEnc: Please use -b:a or -b:v, -b is ambiguous
[i] VideoEnc: [mpeg @ 0412e960] VBV buffer size not set, muxing may fail
[i] VideoEnc: Output #0, mpeg, to 'C:\Users\Superuser\Desktop\kip.mpg.mpg':
[i] VideoEnc: Metadata:
[i] VideoEnc: encoder : Lavf54.63.100
[i] VideoEnc: Stream #0:0: Video: mpeg2video, yuv420p, 640x360, q=2-31,
3000 kb/s, 90k tbn, 25 tbc
[i] VideoEnc: Stream mapping:
[i] VideoEnc: Stream #0:0 -> #0:0 (rawvideo -> mpeg2video)
[i] AudioEnc: libpostproc 52. 2.100 / 52. 2.100
[i] AudioEnc: Trailing options were found on the commandline.
[i] VideoEnc: frame= 63 fps=0.0 q=2.5 size= 338kB time=00:00:02.40
bitrate=1153.7kbits/s
[i] AudioEnc: [wav @ 0037bb80] max_analyze_duration 5000000 reached at 5016000
microseconds
[i] AudioEnc: [wav @ 0037bb80] Estimating duration from bitrate, this may be
inaccurate
[i] AudioEnc: Input #0, wav, from 'pipe:':
[i] AudioEnc: Duration: N/A, bitrate: 128 kb/s
[i] AudioEnc: Stream #0:0: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz,
stereo, s16p, 128 kb/s
[i] AudioEnc: Output #0, ac3, to 'C:\Users\Superuser\Desktop\kip.mpg.ac3':
[i] AudioEnc: Metadata:
[i] AudioEnc: encoder : Lavf54.63.100
[i] AudioEnc: Stream #0:0: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s
[i] AudioEnc: Stream mapping:
[i] AudioEnc: Stream #0:0 -> #0:0 (mp3 -> ac3)
[i] VideoEnc: frame= 123 fps=119 q=2.5 size= 690kB time=00:00:04.80
bitrate=1177.6kbits/s
[i] AudioEnc: size= 163kB time=00:00:06.93 bitrate= 192.1kbits/s
[i] VideoEnc: frame= 173 fps=112 q=2.5 size= 996kB time=00:00:06.80
bitrate=1199.9kbits/s
[i] VideoEnc: frame= 234 fps=114 q=2.5 size= 1348kB time=00:00:09.24
bitrate=1195.1kbits/s
[i] AudioEnc: size= 223kB time=00:00:09.49 bitrate= 192.1kbits/s
[i] VideoEnc: frame= 295 fps=115 q=2.0 size= 1742kB time=00:00:11.68
bitrate=1221.8kbits/s
[i] AudioEnc: size= 283kB time=00:00:12.05 bitrate= 192.1kbits/s
[i] VideoEnc: frame= 348 fps=113 q=2.5 size= 2074kB time=00:00:13.80
bitrate=1231.2kbits/s
[i] AudioEnc: size= 337kB time=00:00:14.36 bitrate= 192.1kbits/s
[i] VideoEnc: frame= 409 fps=113 q=2.0 size= 2502kB time=00:00:16.24
bitrate=1262.1kbits/s
[i] AudioEnc: size= 391kB time=00:00:16.66 bitrate= 192.1kbits/s
[i] VideoEnc: frame= 466 fps=113 q=2.0 size= 2884kB time=00:00:18.52
bitrate=1275.7kbits/s
[i] AudioEnc: size= 445kB time=00:00:18.97 bitrate= 192.1kbits/s
[i] VideoEnc: frame= 520 fps=112 q=1.6 size= 3268kB time=00:00:20.68
bitrate=1294.6kbits/s
[i] AudioEnc: size= 499kB time=00:00:21.27 bitrate= 192.0kbits/s
[i] VideoEnc: frame= 576 fps=112 q=2.5 size= 3592kB time=00:00:22.92
bitrate=1283.8kbits/s
[i] AudioEnc: size= 553kB time=00:00:23.57 bitrate= 192.0kbits/s
[i] VideoEnc: frame= 634 fps=111 q=2.0 size= 3976kB time=00:00:25.24
bitrate=1290.5kbits/s
[i] AudioEnc: size= 607kB time=00:00:25.88 bitrate= 192.0kbits/s
[i] VideoEnc: frame= 697 fps=112 q=2.0 size= 4384kB time=00:00:27.76
bitrate=1293.7kbits/s
[i] AudioEnc: size= 667kB time=00:00:28.44 bitrate= 192.0kbits/s
[i] VideoEnc: frame= 750 fps=113 q=2.5 Lsize= 4772kB time=00:00:29.96
bitrate=1304.8kbits/s
[i] VideoEnc: video:4742kB audio:0kB subtitle:0 global headers:0kB muxing
overhead 0.638489%
[i] AudioEnc: incomplete frame
[i] AudioEnc: Error while decoding stream #0:0: Invalid data found when
processing input
[i] AudioEnc: size= 702kB time=00:00:29.94 bitrate= 192.0kbits/s
[i] AudioEnc: video:0kB audio:702kB subtitle:0 global headers:0kB muxing
overhead 0.000000%
[E] Error: CLI: The multiplexing process failed with error code 1 (00000001).
Check the log for possible error messages.
The muxer setting required 'Delete output file before starting' checked.
Codecs gone, not showing up in VirtualDub or other software....
By ggouweloos in forum Video ConversionReplies: 19Last Post: 14th Sep 2012, 23:24 -
VirtualDub Compression Codecs All missing?
By blazr in forum Newbie / General discussionsReplies: 0Last Post: 29th Feb 2012, 05:14 -
A few questions about bitrate,codecs and virtualdub
By alibaba12 in forum Newbie / General discussionsReplies: 21Last Post: 5th Jan 2012, 17:30 -
Codecs for WMM | WMP | VirtualDub
By TheGame111 in forum EditingReplies: 1Last Post: 22nd Dec 2010, 17:42 -
vob to mov. Problem with virtualdub codecs
By jogonan in forum Video ConversionReplies: 4Last Post: 24th Nov 2009, 05:29
