So I have an MP4 file and I want to chop out a section in the middle. I'm looking for the best way to do this.
The file doesn't have to end up as an MP4 file if it's easier to convert it to something else and then do the edits or something like that.
Is there a free program that will let me do this easily? Basically I just want to say Start here, End here, and cut everything in between and resave the file.
Thanks!
You could try AVIDemux. Highly compressed formats like MP4 and H.264 are not really made to edit, especially frame accurate editing, so you may need to re-encode, at least at the cut point to keep everything in sync.
Alternately, you could re-encode to a lossless format like HuffyUV or Lagarith, then edit, then convert back to a more compact format without too much loss. Downside, huge files for most lossless formats.
But that's not simple.
I'd try the simple way first.
VideoPad Video Editor will do it. Load your clip, select start point and use the scissors, select the end point and use the scissors, right-click the clip in between the cuts and 'delete' it. Go to Export and save as mp4 with resolution set to 'Youtube HQ'. Seems to do a decent job, but I have only used it this one time to test it.
crop m2v video file
By robbtek in forum Video ConversionReplies: 3Last Post: 17th Feb 2011, 11:58 -
Program to crop MP4 files without re-encoding
By milatchi in forum Video ConversionReplies: 3Last Post: 20th Aug 2010, 11:13 -
How do you crop off the edges of an mpeg file?
By True Colors in forum EditingReplies: 3Last Post: 11th Dec 2009, 14:04 -
how to crop a video, only use a section
By Rkermit in forum EditingReplies: 2Last Post: 17th Mar 2009, 17:14 -
best, easiest way to cut bad section out of vob file
By dblake2 in forum EditingReplies: 2Last Post: 16th May 2008, 18:53
