Guys,
I'm having a problem converting from Blu-ray disc to MKV; Let me try and explain the issue.
I have the Blu-ray disc for the movie 'Prometheus', and I simply want to convert it to a 720p MKV for playback on my Samsung Galaxy Note 2. I'm using Handbrake to do so. Almost everything is working out prefectly fine -- except that the image is stretched in Height!!
The resolution of the movie on disc is 1920 X 1080, but it does have the Black Bars on top & bottom when you play it, to preserve aspect ratio. So in my "Picture Settings" in Handbrake, I put in "1280" in the Width and I select "Keep Aspect Ratio". It automatically gets the Height of 534. After this, I have tried all 4 Anamorphic settings --- None, Strict, Loose & Custom --- But with all 4, I get the exact same result. The Width is fine but the height is stretched to make it full screen (1280 X 720). I want to preserve the image ratio, including any Top & Bottom bars to preserve the aspect ratio, but somehow it won't do that. The result MKV is stretched in height no matter what I do -- and I don't get the top & bottom bars.
What do I have to do to get the correct image as the original movie, just reduced to 720p as opposed to 1080p?
Thanks!
I don't suffer from Chronic Insanity & Psychosomatic Multiple Personality Disorder!
I enjoy every moment of it! -
Disable the Cropping. Set it to Custom and 0 0 0 0 instead of automatic.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
Burning a MKV to Blu Ray Disc
By bbren43 in forum MacReplies: 37Last Post: 23rd Jan 2015, 17:29 -
Burn mkv/whatever to blu ray disc playable on Vizio Blu ray player?
By Eric1987 in forum Authoring (Blu-ray)Replies: 3Last Post: 1st Dec 2012, 22:41 -
Blu-Ray to MKV with forced subtitles - Size of file not issue
By rajsharma714 in forum Blu-ray RippingReplies: 3Last Post: 16th Nov 2012, 22:25 -
Blu-Ray player that plays MP4 and/or MKV from disc (not only USB)?
By cosmin in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Dec 2010, 23:49
