Hi, can anyone recommend free software to capture to .m2ts?
?? capture from what?
it is a device that utilizes a hardware encoder to only capture to .m2ts-roxio game capture hd pro
Can I capture more video formats other than M2TS in the Capture application?
No. M2TS is the native video format from the hardware chipset embedded in the capture device. By recording in this video format, you can get the best performance and picture quality from the product. -
i'm sorry, please clarify
if the device produces .m2ts as the output, then you need to record that output and then CONVERT it
i assume this hardware records to a PC or memory card
if so you need to copy the file to the pc then convert it
if the hardware creates m2ts files, why would you need software to capture them
do you mean software to 'RECORD' them to the hard drive,
you have the device but NOT the software that is supposed to come with it ? -
i have the roxio software but it really isn't good. the device i suppose only can output .m2ts so i need a free software that does the conversion i suppose, capture to.
Unless you can figure out how to build a filter graph for the Roxio Game Capture HD Pro to use GraphStudio or GraphEdit for capture, you will have to use the manufacturer's capture software.
The Roxio Game Capture HD Pro encodes using hardware and can't provide uncompressed input, so it won't work with third-party capture software. Unless capture software is written to specifically support a particular capture device, it only accepts uncompressed input from a capture device and uses its own software encoders for compression. -
I found something for you, mentioned in another thread: rcTVCap, plus information about building filter graphs. Read this page: http://blog.arogan.com/2008/06/hauppauge-hd-pvr-model-1212.html
M2TS to AVI - best free tool?
By CompVid in forum Video ConversionReplies: 9Last Post: 19th Jul 2016, 16:10 -
free tool to convert m2ts to mkv ?
By tagada45 in forum Video ConversionReplies: 7Last Post: 17th Feb 2014, 07:28 -
Best (hopefully free!) software to capture analog video?
By The Big Cheese in forum Capturing and VCRReplies: 3Last Post: 7th Sep 2011, 21:52 -
What would you say is the best free video capture software?
By meneedit in forum Capturing and VCRReplies: 6Last Post: 22nd Feb 2011, 05:48 -
Sony Video Hi-8 Editing Disk Lost. Need Free Capture/Edit Software
By Classic '57 in forum Newbie / General discussionsReplies: 13Last Post: 14th Jun 2010, 23:08
