  1. Member godai's Avatar
    Oct 2012
    United States Florida
    hi
    i have one problem with this card, after record or preview, i get horizontal lines in video, problem appers with virtualdub and wintv game mode, i try two hvr 2250 and they get same problem
    also i test with one hvr 1600 , it works fine.
    thanks for help!
  2. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    The lines look digital in nature, to me. Like some sort of data transportation glitch after the signal is digitzed.
    Have you tried placing the card in a different slot in the computer?
  3. Member godai's Avatar
    Oct 2012
    i will try that, i already try with other hvr 2250 same result, like i said before with hvr 1600 lines doesnt appears
    thanks
  4. Member godai's Avatar
    Oct 2012
    thanks i solved change slot fix , but looks like colossus not works well with game mode
