I get this error when I try to capture using virtualdub above the dimensions 320x240...
Btvid: can't capture at this time. Either:
A) Capture attempted from full size (interlaced) overlay mode or Quartzsight camera overlay mode. Switch to preview mode to capture.
B) Memory Allocation Failure. Restart Application.
I have tried switching to preview mode and the video then becomes jerky and when i capture, it comes out as crap. I alos tried restarting virtual dub and that doesn't work either. I can capture with the dimensions 320x240 and under, but i can't capture above those dimension.
Help would be appreciated.
Thanx!
need hardware specs buddy. are you using the vfw or wdm wrapper? capture card? os? speed of computer? color of computer?
I am getting a similar error and I recall VirtualDub givving me a warning about the screen size and a suggestion for changing the settings. my problem is when I to change the settings I lost the tip and cannot find it again.
You get that error when you try to capture more than 240 lines and overlay is turned on. Turn overlay off and use normal preview and everything should be ok.
thnx TheInformer
that solved the issue of size... now I need to work on the OE and OD error that follow. Gotta love Winblows
I have been struggling with this same issue as well in Virtual Dub - cannot go beyond 320X240 capture.
PIII 1.2g/ 512 ram/ ATI 7200 (64mg vivo) - capturing from VHS or Video Camera.
Video driver is ATI - 6.13.10.6071
VirtualDub 1.4.10
Windows XP pro
Have installed the ATI MMC 7.6 because thought the native codecs for ATI card might help but did not.
Video overlay is not selected - Preview is. Where can I tell if I am capturing at more than 240 lines?
Tried an older ATI driver but same result.
Have tried capturing in the ATI MMC at higher res (720x480) for best initial resolution with no problem. Would like to use VDub for filters (noise).
Any suggestions or help greatly appreciated.
Jesse
Windows 7, Virtual Dub (any Version), BlackMagic Intensity Pro = No Capture
By Digital-Overload in forum Capturing and VCRReplies: 2Last Post: 22nd May 2011, 11:57 -
error message when adding SSA. file to virtual dub
By fredsieg1937 in forum SubtitleReplies: 1Last Post: 24th Sep 2009, 21:53 -
virtual dub "non-zero start position" error
By DaneClark in forum EditingReplies: 1Last Post: 17th Aug 2009, 21:24 -
Error when trying to compress with Virtual Dub
By las7h0p3 in forum Video ConversionReplies: 2Last Post: 7th Oct 2008, 14:39 -
Auto Gordian Knot error issued by Virtual Dub
By loninappleton in forum Video ConversionReplies: 10Last Post: 30th Apr 2008, 12:56
