I try to make an effort to prepare and backup things in every way prior to reformatting. This was naturally an issue I forgot to prepare for.
I had so many filters that I don't even know where to begin, but I'll try.
Being able to utilize TFM(), TDecimate(), ConverToUV12() would be nice start. Even MPEG2Source won't load, despite my thinking I properly installed it.
When searching I go in circles. Countless pages give usage examples and such, but I can't find the actual download links.
Sorry for the newbie question![]()
MPEG2Source is part of DGMPGDec package (DGDecode.dll)
http://neuron2.net/dgmpgdec/dgmpgdec.html
http://hank315.nl/ (scroll down to bottom)
TFM, TDecimate are part of TIVTC.dll
http://web.missouri.edu/~kes25c/
http://web.missouri.edu/~kes25c/TIVTCv105.zip -
http://avisynth.org/mediawiki/External_plugins and http://avisynth.org/warpenterprises/ is normally a good start when looking for plugins
"ConverToUV12" afaik there is only ConverToYV12 which is part of the core filters and thus requires no special external dll.
Not sure what you call 'properly install', normally you extract the filters somewhere and load them in the Avisynth script. (I never use the auto-loading, packing dlls&co directly in the plugins folder tends to cause problems unless you make sure you got no conflicting plugins/scripts.)Even MPEG2Source won't load, despite my thinking I properly installed it. -
Just a quick post before downloading and testing. Yes, the "UV12" was a typo
... I even left out the "t" before "To" :/
Thanks much for the help. I'll check it out soon.
AVISynth will not load plugins Win-7 (64)
By Sartorius48 in forum Newbie / General discussionsReplies: 9Last Post: 31st Dec 2012, 22:17 -
More strangeness with Premiere Pro & Avisynth that I can't figure out
By Asterra in forum Video ConversionReplies: 15Last Post: 16th Jun 2011, 22:39 -
Is there a way to use avisynth plugins/filters within Virtualdub?
By Milardo in forum EditingReplies: 5Last Post: 5th Jan 2011, 04:52 -
How do I figure out what power supply my computer has?
By Bill in NH in forum Newbie / General discussionsReplies: 4Last Post: 26th Mar 2010, 01:15 -
Basic question about AVISynth plugins
By sd_smoker in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2008, 12:04
