Page 2 of 2
FirstFirst 1 2
Results 31 to 33 of 33
  1. Member DB83's Avatar
    Jul 2007
    I should mention that it is pretty 'green' of you to pass on these details in this way. Anyone can see them and access the folder.
    And not just to download - delete content etc.
    Well I have the vob now and, off course, it shows no sign of life. I will try it on some tools and report back later.
  2. I am not worried on the codes.........files are actual and info are not actual. All can be changed later or as per problem until I get URL to access only. You don't know how much I appreciate all the help! Can't say enough!!
  3. Member DB83's Avatar
    Jul 2007
    Ok.
    A very quick look at this suggests that the audio should run for 1 hr 44 mins. The audio size is 95 meg. But the audio is totally empty as far as I can tell but that may be due to the very low bit-rate and my system can not read it.
