  1. Is there anything that needs to be fixed based on these unfiltered screenshots?
    Feb 2013
    Norway
    It looks good enough for me.
    But do compare with screenshots from original movie. Then you can see if the Aspect Ratio is distorted.
  3. I did not resize. There are a few combed frames which i fixed by using vinverse.
    Sample : http://www.mediafire.com/?8ne8dmx7b1pi7mq
    Feb 2013
    Norway
    Looks like you did a great job in decombing.
    But I will also mention that AR can be distorted even if you don't resize. That is, if the program is setting up a wrong value for DAR and SAR.
  5. DAR can be set during the muxing process in mmg.
