how do you record? the hotkey isnt working..
Results 1 to 15 of 15
Post in http://forum.dxtory.com/index.php?board=2.0 and give as much information as possible.
it isnt recording because the hotkey isnt responding. what other information would be needed...
^ bump ?
i mean the record key just doesnt register so cant record,.. this is commented on a lot in utube and must be a common problem... -
is working,.. it seems. i got an output file so yea,..
settings all screwed but can work on that, is this my best option for screen capturing games and any desktop work. want 60 fps with ut then can reencode ?
like if i get a beast of a pc am i going to be able to play games at 144 fps on a monitor like the asus VG278HE which runs 144hz ,.. and record at 144 with ut and then renecode.
or record with ut at 60fps at 100hz playing a game....
don't want to buy unless i know this is the software i need to be getting..
it seems there is nothing else really that compares in terms of screen capturing at highest frame rate while playing games / watching video etc... ?Last edited by krohm; 25th Feb 2013 at 05:27.
Yep. You can do bandicam instead. Records both desktop and in game. Also has support for external codecs. http://www.bandicam.com/
ok, using bandicam and seems to be recording in ut at 30fps,.. file size is huge obv but thats ok, seems like the frames are not exactly as fast as when im actually moving clicking around.. is that just a pc limitation.. even at 60fps
dxtory is able to use ut as well though right ? but dxtory is better for recording games in terms of no loss of frame rate while recording and playing
is bandicam similar in this regard ? -
I'm not quite sure with the trial version. I paid for the full version. Perhaps you should take the time to explore the program. Read up on the guide for Bandicam. You can change the video recording settings to record at 30fps, 40fps, 50fps and even 60fps.
If you visit their forums, Bandicam has a guide that shows how to record without any lag as well. -
im using badicam and its recording at 60fps and 30fps in ut and all works ok.
but it isnt 100% smooth but that could be my pc? 90 gb files..
whats causing the slow down ?
just saw youtube vid that said dxtory you can record at 60fps while playing and bandicam 30fps ..
so for games in that sense dxtory is the better option for games but pretty much identical other than that ?Last edited by krohm; 3rd Mar 2013 at 06:49.
Dxtory & Sony Vegas
By xxsashixx in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2010, 01:53
