Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Closed Thread
  1. ok i remuxed a bluray using tsremux and mkvmerge and i even ripped the movie using staxrip from the original bd source and they both seem to work on vlc player and my samsung tv via usb play but when i use my sony home theater system the movies play for few min then they freeze but other rips that i download from internet seems to work properly. and my video contain dth-hd ma and to enjoy it i need my home theater otherwise there is no point for all this .........so pllz can some 1 tell me wat i am doing wrong
    and 1 more thing i used tsmuxer and remuxed into .ts format and the video works fine but without subtitles cauz my home theater dosent read bluray sup format from usb play
    remuxed video mediainfo
    General
    Complete name                            : H:\BD-REMUX\00800.mkv
    Format                                   : Matroska
    Format version                           : Version 2
    File size                                : 26.4 GiB
    Duration                                 : 2h 23mn
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 26.4 Mbps
    Encoded date                             : UTC 2013-02-13 05:08:45
    Writing application                      : mkvmerge v3.4.0 ('Rapunzel') built on May 15 2010 09:38:20
    Writing library                          : libebml v0.8.0 + libmatroska v0.9.0
    Video
    Format profile                           : High@L4.1
    Format settings, ReFrames                : 4 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 2h 23mn
    Bit rate mode                            : Variable
    Maximum bit rate                         : 33.2 Mbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Audio
    Format                                   : DTS
    Format/Info                              : Digital Theater Systems
    Format profile                           : MA / Core
    Mode                                     : 16
    Format settings, Endianness              : Big
    Codec ID                                 : A_DTS
    Duration                                 : 2h 23mn
    Bit rate                                 : Unknown / 1 509 Kbps
    Channel(s)                               : 6 channels
    Channel positions                        : Front: L C R, Side: L R, LFE
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 24 bits
    Compression mode                         : Lossless / Lossy
    Title                                    : DTS-HD.MA 5.1
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Text
    Format                                   : UTF-8
    Codec ID                                 : S_TEXT/UTF8
    Codec ID/Info                            : UTF-8 Plain Text
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    this is of ripped mkv
    General
    Complete name                            : H:\BD-REMUX\00800(1).mkv
    Format                                   : Matroska
    File size                                : 11.3 GiB
    Duration                                 : 2h 23mn
    Overall bit rate                         : 11.3 Mbps
    Encoded date                             : UTC 2013-02-14 23:57:35
    Writing application                      : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep  2 2012 15:37:04
    Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
    Video
    Format profile                           : High@L4.0
    Duration                                 : 2h 23mn
    Width                                    : 1 904 pixels
    Height                                   : 800 pixels
    Display aspect ratio                     : 2.40:1
    Writing library                          : x264 core 128 r2216 198a7ea
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Default                                  : Yes
    Forced                                   : No
    Audio
    Format                                   : DTS
    Mode                                     : 16
    Codec ID                                 : A_DTS
    Duration                                 : 2h 23mn
    Bit depth                                : 24 bits
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Text
    Format                                   : UTF-8
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Menu
    00:00:00.000                             : en:00:00:00.000
    00:04:28.477                             : en:00:04:28.477
    00:07:32.452                             : en:00:07:32.452
    00:12:47.392                             : en:00:12:47.392
    00:16:47.465                             : en:00:16:47.465
    00:21:37.338                             : en:00:21:37.338
    00:25:00.290                             : en:00:25:00.290
    00:29:25.222                             : en:00:29:25.222
    00:35:06.146                             : en:00:35:06.146
    00:38:27.764                             : en:00:38:27.764
    00:41:24.440                             : en:00:41:24.440
    00:46:22.905                             : en:00:46:22.905
    00:50:48.629                             : en:00:50:48.629
    00:54:53.290                             : en:00:54:53.290
    00:59:38.742                             : en:00:59:38.742
    01:05:14.244                             : en:01:05:14.244
    01:10:16.671                             : en:01:10:16.671
    01:17:09.750                             : en:01:17:09.750
    01:20:55.059                             : en:01:20:55.059
    01:26:10.374                             : en:01:26:10.374
    01:31:49.754                             : en:01:31:49.754
    01:37:04.527                             : en:01:37:04.527
    01:40:49.085                             : en:01:40:49.085
    01:43:45.970                             : en:01:43:45.970
    01:45:54.723                             : en:01:45:54.723
    01:52:10.599                             : en:01:52:10.599
    01:54:45.796                             : en:01:54:45.796
    01:58:13.044                             : en:01:58:13.044
    02:02:49.112                             : en:02:02:49.112
    02:09:38.646                             : en:02:09:38.646
    02:14:49.623                             : en:02:14:49.623
    02:17:46.425                             : en:02:17:46.425
    this is of working mkv
    General
    Complete name                            : D:\moviez\s7.mkv
    Format                                   : Matroska
    File size                                : 7.65 GiB
    Duration                                 : 1h 41mn
    Overall bit rate                         : 10.8 Mbps
    Encoded date                             : UTC 2012-12-20 10:46:42
    Video
    Format settings, ReFrames                : 5 frames
    Duration                                 : 1h 41mn
    Bit rate                                 : 9 246 Kbps
    Height                                   : 800 pixels
    Bits/(Pixel*Frame)                       : 0.251
    Stream size                              : 6.42 GiB (84%)
    Writing library                          : x264 core 119 r2106 07efeb4
    Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9246 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    Audio
    Format                                   : DTS
    Mode                                     : 16
    Codec ID                                 : A_DTS
    Duration                                 : 1h 41mn
    Bit rate mode                            : Constant
    Bit rate                                 : 1 509 Kbps
    Bit depth                                : 24 bits
    Delay relative to video                  : 11ms
    Stream size                              : 1.07 GiB (14%)
    Title                                    : english
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    Text
    Format                                   : UTF-8
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Buy the movie.
    Unique ID : 201129891230348485881258755753430968463
    https://forum.videohelp.com/threads/353392-blu-ray-remux-problem
  3. i bought the bluray
    ripped to my pc and then remuxed it to get rid of trailers
    n now i am having problem with it so can u help.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You bought it and ripped it in 14 Minutes?
    Nice try jackass.
    canada
    Thread closed.
