Hi,
I have a DVD ripped onto HDD to a VIDEO_TS folder. The content is music videos. What is the best tool and and method/guide to convert it into single mkv (x264)? Also if possible I want set "chapters" so that if I press >> (Next) on the remote, it goes to the next song.
Thanks.
Thanks.
Also read that VidCoder may also do the job. Will look into both.
https://www.videohelp.com/tools/VidCoder -
Shoot, missed the part where you said you wanted h264. MakeMkV won't re-encode to H264 for you, it will simply put the existing mpeg2 of the dvd into an mkv file with no compression.
So, if you absolutely need H264, then VidCoder, Handbrake, Ripbot264 or other encoding programs that use the X264 encoder will work for you.
What's the best tool to cut/trip MKV videos?
By creamsoda in forum EditingReplies: 16Last Post: 4th Jan 2019, 16:36 -
Convert 10bit MKV videos in to 8bit MKV with XMedia
By RaW D Coy in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2012, 13:10 -
Batch method to convert subtitles embedded in mkv's
By invinciblegod in forum SubtitleReplies: 4Last Post: 9th Aug 2012, 02:11 -
Convert video_ts and/or DVD to MKV
By rocks911 in forum Video ConversionReplies: 2Last Post: 4th Oct 2011, 07:11 -
A reliable method to convert MKV to MP4
By Alphonse55 in forum MacReplies: 7Last Post: 18th Feb 2010, 21:32
